Author Topic: Kenwood TS-140 Memory Channel/VFO Control knob "skips"  (Read 19781 times)
N4ATS
« Reply #15 on: April 14, 2013, 02:37:42 PM »
It takes a grand total of 60 seconds to do this....Did it work for you?
Cheers
N4ATS
« Reply #16 on: April 15, 2013, 02:14:01 PM »
Well what happened?Huh
« Reply #17 on: April 16, 2013, 06:55:50 AM »
 It worked great for me but not shure about Mike, he must have got lost.
KE3WD
« Reply #18 on: April 16, 2013, 02:34:07 PM »
Maybe he don't wanna tell ya what that 1 HP Hammer Drill did...
 Shocked
« Reply #19 on: April 17, 2013, 07:35:28 AM »
thats funny
 Shocked
Grin
« Reply #20 on: April 17, 2013, 07:46:03 AM »
If you are not real careful you could easily destroy it in a flash with off axis torque or thrust loads.
N4ATS
« Reply #21 on: April 17, 2013, 11:57:28 AM »
so what , its bad anyways...
I spin them all the time , works like a champ. Common sense tells you to stay straight on axis...
« Reply #22 on: April 17, 2013, 12:19:27 PM »
Well sometimes what is planned and what happens is two different things.
N4ATS
« Reply #23 on: April 17, 2013, 02:26:06 PM »
Just for grins , I pulled out a radio , stuck my cordless drill on it and wobbled it from side to side while spinning...Nadda. Turns out the shaft / barrel is long enough that it will not let the inside portion go off axis. I could understand if the shaft did not have a barrel , however typically they are 1/4-3/8 long reducing risk of wobble. Let it rip....
Amateur Radio, Think simplicity
« Last Edit: April 17, 2013, 02:28:15 PM by N4ATS » Logged
N4MJR
« Reply #24 on: April 18, 2013, 04:04:45 PM »
I have a TS680, which I believe is the same radio but includes 6m. To the best om my knowledge it has a mechanical encoder for the memory channel knob. The encoder has a port which is visible from the face of the radio if you remove the knob. I gave a couple of squirts of canned air followed by a couple of squirts of contact cleaner (be certain the cleaner doesn't have lubricant). And it works like new. Also, the same procedure works for the sliders, which are also fraught with problems. This works well for me. Good luck, I hope you get it fixed. Michael N4MJR - C6AMR
« Reply #25 on: April 19, 2013, 12:43:16 PM »
 HELLOOOOO  MIKE !!!!!   WHATS UP HuhHuh
