Author Topic: What is it?  (Read 5028 times)
K4EZD
« on: April 16, 2013, 04:25:15 PM »
I use DM780 for psk digital and on the waterfall on 10 meters (28.120) I see thin vertical lines that never vary in frequency or strength.  Are they a carrier for some mode unknown to me or is it local QRM?  Not really a problem but just don't know what it is.
Thanks.
 Wink
VE3FMC
« Reply #1 on: April 17, 2013, 04:13:09 AM »
Thanks.
 Wink
Are the lines there constantly? Meaning if there is no propagation do you still see those lines in the waterfall?
If so then it is local QRN. I tuned to 28.120 at 11:10 UTC and I see two thin lines on the waterfall here.
One is located just below the 500 marker and the other is almost at 2200. I suspect that is local QRN of some sort but it would not likely be strong enough to interfere with a signal. Thin lines, they are not as wide as the marker.
K4EZD
« Reply #2 on: April 17, 2013, 11:38:02 AM »
Thanks VE3FMC.  That was it.  It does not really interfere but I didn't recognize what it was.   Smiley
« Reply #3 on: April 17, 2013, 12:29:54 PM »
Thanks.
 Wink
If you audio input level to sound card is too high it can produce multiple "echos" in waterfall.
AJ4WC
« Reply #4 on: April 18, 2013, 04:54:30 AM »
You're seeing a beacon transmitting.  If you turn up the volume on your receiver, you can hear it.
KG4RUL
« Reply #5 on: April 18, 2013, 02:07:04 PM »
Not always the case.  I am looking at my waterfall and there are constant lines on my waterfall about 120 Hz apart.  They are not all beacons.  What I have discovered is that they appear when I use my wireless router and are coning from the switching power supply.
K2QB
« Reply #6 on: April 19, 2013, 02:09:59 PM »
You may be looking at JT9 traces.
