Author Topic: FT450at MARS mod  (Read 7039 times)
WV8KFA
« on: April 17, 2013, 07:33:50 AM »
I purchased a 2nd hand Yeasu FT450at and was wondering HOW can I tell (without removing the cover) if it has been modded for MARS operation.
Upon receiving the unit I did a FULL RESET to put all settings back to factory and remove what they previous owner had saved.
Robert Kelly - WV8KFA
Plateau Amateur Radio Association, President - PIO
www.parawv.com
K9YLI
« Reply #1 on: April 17, 2013, 08:23:48 AM »
hook to a dummy  load and see if it will transmit  on  14.405..  (used to be a mars frequency).
KE3WD
« Reply #2 on: April 18, 2013, 01:16:16 PM »
If it TRANSMITS anywhere outside of any Ham band, it has been modded.
Just turn the Big Knob to a band edge, then turn past it and, with the rig attached to a Dummy Load and not an antenna so you don't break the regs, see if it will transmit there.
WV8KFA
« Reply #3 on: April 18, 2013, 04:24:14 PM »
OK, I thought if it would transmit ANYWHERE outside the normal band might be an easy way to tell.  I just wasnt sure if, because of the reset, I might have to go into an extended menu and change something.
www.parawv.com
WV8KFA
« Reply #4 on: April 19, 2013, 07:52:19 AM »
Just to make this final, I did a test using dummy load on 14.405 and then moved to 14.650 and it DID transmit (or at least did not give a TX ERROR) on those freq.
Looks like it HAS been modded for MARS.  Thanks for the help.
www.parawv.com
