Author Topic: random or long wire for the KX1  (Read 17857 times)
KB2FCV
« Reply #15 on: May 29, 2013, 10:31:04 AM »
Agreed, adding some counterpoises would help the elecraft suggested antenna that I use and it would not add too much weight. For hiking, I find it adequate and easy to setup. I'm usually on the air in under 5 minutes.
There are certainly better antennas out there. It all depends what your needs are.
« Reply #16 on: May 29, 2013, 12:19:51 PM »
I used two 25' wires for those bands. One goes up into a tree at an angle and the other is place on the ground under the upper wire.
W1JKA
« Reply #17 on: May 30, 2013, 03:14:37 AM »
Re:WX7G
Did you connect direct or via tuner? All 3 bands 20/30/40? What were your average results? Thanks
« Reply #18 on: May 31, 2013, 02:06:06 PM »
This is direct to the KX1 internal tuner. It's difficult to say how well this worked as I have no reference. But it made contacts without too much work and I was quite happy with it.
