Author Topic: MFJ-927 autotuner / system resets to fix problem  (Read 11266 times)
AC4RD
« on: April 24, 2013, 04:14:04 AM »
I said this in another forum, and it occurs to me to put it in the "repairs" forum in hopes it might be useful to someone doing a search:
I put my MFJ-927 autotuner in a spot I thought was protected from the weather, but I was wrong about that.  The tuner was fairly full of rainwater when it finally stopped working.
I took off the cover and dried it for a couple of days, then tried the "reset" process.  It failed, several times in a row.  I went through all the diagnostics and resets in the manual, and it wasn't working.  Ordinarily, I would have given up on it after a half-dozen tries, but I had nothing better to be doing, so I kept doing resets.  After maybe a dozen "system resets," the thing suddenly started working right.  :-)  It's been back up for a few months now and works perfectly well now.
So, short version:  trying LOTS of "system reset" procedures isn't going to hurt, and it might just help.  FWIW.
KA4POL
« Reply #1 on: April 24, 2013, 04:26:39 AM »
You certainly have done according to the manual. So this would indicate a contact problem in at least one of the buttons.
W6LMP
« Reply #2 on: May 13, 2013, 10:48:50 PM »
Thanks for your post, my MFJ-927 began endless searching on 17M today.  It's the band I use the most and it has been at the base of my 43' DX Engineering fast taper vertical since October 2009.  I don't suspect water here in San Diego County but I'll having a look in there and try the reset process.
KE3WD
« Reply #3 on: May 14, 2013, 02:34:10 PM »
Sounds like you perhaps did not know to put a Drip Loop on the wiring, allowing water to run towards the gland?
Drip Loop.
