Author Topic: FT-897D Boom Headset  (Read 4516 times)
KB1YWP
« on: April 27, 2013, 05:19:11 PM »
Hello across the board. I'm thinking of purchasing the YAMAHA CM500 headset for my FT-897D rig.
Based on the past reports it seems like a decent "affordable" set for my current situation.
Being a Ham newbie, Would there be any other hardware necessary ? IE wired plug end, special cable and such ?
What would be the preferred method of keying the mike. Some type of foot peddle Pitt switch ?  Just not sure of the best way to proceed at this point.
Any pointers ?   Thanks in advance.
VA7CPC
« Reply #1 on: April 27, 2013, 10:23:31 PM »
Yes, you'll need an adapter of some kind.   The CM500 comes with "computer-standard" 1/8" phone plugs.
In the eHam.net reviews for the CM500:
http://www.eham.net/reviews/detail/7494
there's somebody with a Yaesu rig who bought an adapter from W2ENY.   The review is about the 5th one from the top.  You may find other suggestions in those reviews.
.             Charles
PS -- there's even a YouTube video --
http://www.youtube.com/watch?v=WZo9GDTKDWA
N0IU
« Reply #2 on: April 28, 2013, 06:30:51 AM »
Of course its your money and you can spend it any way you want, but....
My suggestion (and it is worth exactly what it cost you) would be to get something made specifically for amateur radio like the Heil Pro Micro Dual (http://www.heilsound.com/amateur/products/prosetmicrodual/) Its not cheap, at least not compared to the Yamaha headset, but in the long run, it is my opinion that you will get much better results from it.
VA7CPC
« Reply #3 on: April 28, 2013, 03:17:14 PM »
On PTT:
You have two options:
1.  VOX -- which is tempting, until you realize that the first syllable of every phrase will be distorted.  I didn't want to believe that, only realized the truth after monitoring my own signal.
2.  hand switch, or foot switch.
The most elegant foot switch (IMHO) is a small digital-piano sustain pedal, like this:
http://www.amazon.com/Casio-SP-3R-Sustain-Pedal-Keyboards/dp/B000792SBS
Similar units will be in your local music store, filed under "Guitar Stomp Box -- SPST".  Or you can improvise something from a Staples "That was easy!" button -- pull out the electronics, keep the switch.  [That was written-up in QST a while ago.]
Hand switches can be an SPST pushbutton, mounted in a piece of PVC pipe for easy holding and thumb operation.  Bob Heil makes one labelled "ergonomic" with a fancier handle.
Using "non-ham" gear, for ham radio, is perfectly acceptable.   My headphones are Sennheiser HD280 ("studio monitor" phones), my mic is an Audio Technica cardioid dynamic vocal mic.   My compressor/EQ (rarely used) is from Behringer, not W2IHY.  They all work fine with a Yaesu FT-450.
.                  Charles
VA7CPC
« Reply #4 on: April 28, 2013, 03:24:51 PM »
OOps --
I don't know if that Casio sustain pedal is "normally open" or "normally closed" !
This M-Audio pedal (another music-store item) is similar, and can be set either way (you want "normally open" for a PTT switch):
http://www.m-audio.com/products/en_us/SP1.html
.          Charles
KE3WD
« Reply #5 on: April 28, 2013, 03:32:20 PM »
FWIW, so far all three or four of the CASIO keyboards I've experienced used the NO pedal.
Easy enough for the ham operator to ascertain with ohmmeter or continuity checker before buying, though.
Another very good choice for a PTT footswitch are the many types used by secretaries that run dictation machines.  Those things are Heavy Duty in build, and often one can be found that was used on the older machines that have now been replaced with digital types, which means the pedal itself can be had for very little money indeed.  Keep your eyes open.
G8JNJ
« Reply #6 on: April 29, 2013, 08:47:36 AM »
Hi,
Some other suggestions can be found here.
http://g8jnj.webs.com/Boom%20headset.pdf
http://webzoom.freewebs.com/g8jnj/Clansman%20Boom%20headset.pdf
Incidentally foot switches sold for use with Tattoo machines are a good cheap way to provide a foot or desk PTT switch.
I bought some of these to build a College Bowl style Quiz machine. Don't get the round or acrylic ones though. They are junk.
http://www.ebay.co.uk/itm/Tattoo-Machine-Mini-Power-Supply-Square-Rubber-Pads-Metal-Foot-Pedal-Switch-Sit-/390579182217?pt=UK_Health_Beauty_Tattoos_BodyArt_SM&hash=item5af0555a89
Regards,
Martin - G8JNJ
www.g8jnj.webs.com
« Last Edit: April 29, 2013, 08:54:02 AM by G8JNJ » Logged
