Author Topic: FT897 S-Meter Recording  (Read 2898 times)
KG6Q
« on: April 29, 2013, 04:25:01 PM »
Anyone aware of software that will record Yaesu's FT897 S-meter readings via the 897's CAT and PC's USB connection?
S-Meter Lite has this function, but does not operate with the FT897.
I need this capability to help me with nearly three years of power-line RFI chasing.
Thanks in advance for any suggestions.
KG6Q
« Reply #1 on: May 19, 2013, 01:22:15 PM »
I have come across a USB voltage logging device that I believe has the potential of logging S-meter levels over selectable time intervals. It is the Lascar EL-USB-3 Voltage USB Data Logger (http://www.amazon.com/Lascar-EL-USB-3-Voltage-Data-Logger/dp/B003DS0BS2/ref=cm_cr_pr_product_top ) and it comes with software.
The only task is to develop an acceptable hardware I/F between the FT897 meter jack and the EL-USB-3 Voltage USB Data Logger. The 897 appears to source a variable current intended to drive a 1ma analog meter directly, while the EL-USB-3 is intended to record voltage levels.
