Author Topic: More Transmit Problems on PSK31  (Read 3000 times)
W6RLF
« on: January 19, 2002, 04:58:35 PM »
I just got my PSK31 set up, using my Patcomm PC-500, their dedicated cable, and Digipan.
Receive works ok, but on transmit, I can't seem to adjust output down as instructed, no matter how low I set the speaker and wave volume controls.
I'd greatly appreciate any thoughts.
Thanks!
Paul
W6RLF
N5LB
« Reply #1 on: January 20, 2002, 02:40:48 AM »
What kind of sound board are you using?  I use a SB16 and the volume control is very sensitive. I use a Rig Blaster which has an attenuator control also so that helps.
W6RLF
« Reply #2 on: January 20, 2002, 11:52:55 AM »
Thanks.  Using a Sound Blaster Live Sound Card.
Paul
NB6Z
« Reply #3 on: January 22, 2002, 07:13:08 PM »
Paul, I will take a stab at your problem... I have never run into anybody useing the SB LIVE sound card on the digi bands. I am going to guess that you will need to get a true SB 16 bit card for your PC if you want to work the sound card modes. Fortunately, SB16 or compatible cards are very cheap.
