Author Topic: What's a good brand of QRO wattmeter?  (Read 2556 times)
W0BTU
« on: May 04, 2013, 10:27:38 PM »
I'm looking for a fairly inexpensive wattmeter that covers 160 meters and will measure at least up to 2 kW with reasonable accuracy.
I have not kept up with who is currently manufacturing/selling watt meters of reasonable quality. All the Bird wattmeters I've found for sale are too pricey. Please educate me. :-)
N4CR
« Reply #1 on: May 04, 2013, 10:58:39 PM »
Drake W4, Drake W7 off of eBay all the time. They can be calibrated pretty easily with the Drake instructions available all over the web. Reasonably accurate.
New, I like the LP-100 http://www.telepostinc.com/lp100.html
And of course, the veteran in the crowd, a Bird with the proper slug.
73 de N4CR, Phil
Never believe an atom. They make up everything.
W0BTU
« Reply #2 on: May 04, 2013, 11:09:21 PM »
Thanks, Phil! Looks like the W4 is in my price range.
Those are too pricey for me. I'm cheap. :-)
N4CR
« Reply #3 on: May 04, 2013, 11:16:03 PM »
I have an LP-100a. It's great, but after a friend had me repair their amp, I suggested they get a watt meter for tuning.
At Orlando Hamcation, he bought a W4. I've had it in my shack since then.
After using it for a while, I bid on one and got it for myself. It's a really nice wattmeter. I'd suggest you invest in a little calibration work to get it as accurate as it can be.
Also, it's not obvious, but you can remove the sensor portion and have it a couple of feet from where you put the meter cabinet itself.
73 de N4CR, Phil
K7MH
« Reply #4 on: May 05, 2013, 09:52:26 AM »
Another choice is the Autek WM-1 computing wattmeter, a true peak reading wattmeter. It would be my first choice. Only drawback is that they won't give out a schematic for it. They don't want copies of it being made offshore somewhere. It is $160 so pretty close to the price of some non peak reading wattmeters.
If you don't care about the peak reading feature there are a lot of decent wattmeters out there. I used to have a W-4 and it was a good meter. Nice size and the remote sensor is always a good idea.
