Author Topic: 160m 1:1 BALUN 100 watts  (Read 2935 times)
W1AJO
« on: May 05, 2013, 03:59:14 PM »
I am looking for a 1:1 BALUN that will work on 160m and handle 100 watts (it's the most power I have).  A lot of BALUNs I see are for 3.5MHz and up.  Any reccomendations?
Thanks!
WV4L
« Reply #1 on: May 05, 2013, 04:09:28 PM »
http://www.dxengineering.com/search/product-line/ldg-electronics-1-1-current-baluns?autoview=SKU&keyword=1%3A1%20balun
K3VV
« Reply #2 on: May 05, 2013, 05:11:41 PM »
Don't know what kind of load you're trying to match, but you can cook a balun with 100 watts if the match or balance is poor enough.
I'd get this one, not so much for the extra power-handling as for its superb isolation and low dissipation at 1.8 MHz.
http://www.dxengineering.com/parts/dxe-bal050-h05-a
NH7O
« Reply #3 on: May 05, 2013, 06:07:20 PM »
A simple coax coil type balun could work. Loss is not a factor at that frequency, though it will require a fair number of turns. It's best to wind it with the help of an antenna analyzer to make sure the parallel resonance peaks low enough in frequency.
G3TXQ
« Reply #4 on: May 06, 2013, 08:16:23 AM »
17 turns on an FT240-31 core will fit the bill for load impedances up to about 3000 Ohms.
Steve G3TXQ
