Author Topic: Kenwood TS-2000 Save power settings  (Read 3211 times)
K8POS
« on: May 08, 2013, 07:25:21 AM »
I think I already know the answer, but here goes.
Is there a way to save the power output setting into the memory channels on the VHF/UHF side of the radio.
I don't need 100 watts to hit repeaters only 10 miles away.  But more power does come in handy for the ones  way further off.  I have Kenwood's Memory Control Software, and several third party ones, but none seem to offer saving the power output setting.  Pain to have and check it each time.
KG4RUL
« Reply #1 on: May 08, 2013, 11:29:22 AM »
While there is a provision in the command set to set/read power level, the radio does not store this setting for an individual memory channel.
N3DT
« Reply #2 on: May 08, 2013, 01:39:37 PM »
If you turn on the sliders in HRD, the power setting is at the lower right.  I think that's about as easy as it gets.
K8POS
« Reply #3 on: May 09, 2013, 07:03:43 AM »
I figured as much, big OOOPPPPSSS on Kenwood's part that they did not allow for that.
Hate it when I blast a local repeater with 100 watts when 5 or less would work just fine.
AE7IX
« Reply #4 on: May 12, 2013, 06:43:17 AM »
One thing you may not realize is that the radio does maintain different power setting for the HF bands, 2 meter band and 70cm band. You are correct in the fact that it does not save to memory but I would ask why you would set it to 100 watts on 2 meters in the 1st place unless you are working 2 meter ssb.  Grin
