Author Topic: johnson viking II  (Read 8044 times)
WA2JHS
« on: May 16, 2013, 05:11:00 AM »
Hello all....does anyone know of a place where I can get my
Viking II re silkscreened...I have brought it back to life and
would like to restore the front panel...
Bill
KD0REQ
« Reply #1 on: May 16, 2013, 09:04:15 AM »
when I had one as my Novice rig, back in 1970, it needed a case job.  took a picture and blew it up, back when I had color darkroom access... and used Datak lettering to relabel the panel.  I used two Krylon colors that were spot-on matches from the can for the original paint.
AD5X
« Reply #2 on: May 17, 2013, 05:22:37 AM »
I had these folks re-do my Ranger front panel:
http://w4pnt.8k.com/
It is a beautiful job.  I think it looks better than original!
Phil - AD5X
WA2JHS
« Reply #3 on: May 17, 2013, 10:20:09 AM »
Thanks for the info....
Bill
BRIANBURNS
« Reply #4 on: May 21, 2013, 04:26:46 PM »
Hello Bill,
Hayseedhamfest does panel overlays. Those would probably be a lot cheaper than a complete re-finish job.
If you go with them, I would appreciate hearing how you like the result--I've got a Viking II coming that is likely to need the same thing.
Cheers,
Brian Burns
WA2JHS
« Reply #5 on: May 24, 2013, 02:20:56 PM »
Brian, I will check that out too....
Tnx Bill
KA4KOE
« Reply #6 on: November 06, 2013, 11:26:25 AM »
Phil,
I think W4PNT passed some time ago.
Philip
KB4QAA
« Reply #7 on: November 07, 2013, 10:49:15 AM »
http://amfone.net/Amforum/index.php?topic=29688.0
W4PNT died in 2011.
W9GB
« Reply #8 on: November 08, 2013, 08:23:23 AM »
E.F. Johnson Radio Restorations by K1TLI, Chuck Hurley .
http://www.johnsonradioresto.com
Chuck is all about preserving the past with a touch of modern materials.
Chuck has a long history in automotive restorations -- paint and finishes.
Each unit is carefully evaluated for restoration with discrepancies noted.
Special attention is given to undocumented changes/modifications that may have been made.  Every effort is made to return the unit to its original condition/design so that someone else working on it in the future will have a solid baseline from which to work.
Chuck Hurley, K1TLI
274 Fruit St.
Mansfield, MA 02048
Phone: 508-965-7400
Photo Gallery of Chuck's Restoration Work:
EF Johnson Viking Ranger II
http://www.johnsonradioresto.com/Ranger_II.html
EF Johnson Viking Valiant I
http://www.johnsonradioresto.com/Viking_Valiant_Photos.html
http://www.johnsonradioresto.com/Ranger_Photos.html
« Last Edit: November 08, 2013, 08:30:05 AM by W9GB » Logged
