Author Topic: what does it mean RC in part list ?(C225 in main unit in IC-271,IC-471)  (Read 1962 times)
HG5AZR
« on: May 26, 2013, 06:45:22 AM »
Hi!
I like to replace 2.2 mikro 35V RC condenser in icom radio.
1.What does it mean RC?
On condenser is R .
2.If I put  2.2mikro 35V without R?
Thanks
                Zoli
KE3WD
« Reply #1 on: May 26, 2013, 08:54:33 AM »
Viewing where it is, on IC9A, I would think that replacing this capacitor with a modern aluminum electrolytic of proper value and voltage rating should work.
However, if you check the Voltage Rating of C225 in the Parts List, it is listed as:
2.2u @ 50V
So I would not use a 35V capacitor here, I would use one with a minimum 50V rating, okay to go higher than 50V if that's what you have.
