Author Topic: MFJ MEMORY KEYER MFJ-495  (Read 5990 times)
W8PO
« on: May 26, 2013, 11:49:49 AM »
I bought this keyer at Dayton and it works fine until I plug it into my ELEC-KEY jack on the front panel of my IC-746PRO. I have read and read manuals with no luck. Any ideas out there what I am doing wrong?  Huh
Larry W8PO
K7KBN
« Reply #1 on: May 26, 2013, 04:49:24 PM »
Try Page 1 of the Icom manual.  That jack is for the built-in keyer.
Pat K7KBN
CWO4 USNR Ret.
W8PO
« Reply #2 on: May 26, 2013, 07:44:12 PM »
What I have discovered is that according to my manual I use a mono 1/4 jack from the output on my external keyer and that plugs into the straight key jack in the rear. I have done that and when I hit either side of my paddle the rig just sends a long dah abt 2 seconds long. Got me confused. Angry
K7KBN
« Reply #3 on: May 26, 2013, 08:42:28 PM »
W8PO - think about it:  the straight key is a simple SPST switch, so a MONO plug will work.  Key up = open circuit; key down = closed circuit for as long as you hold it closed.
If you're using an external keyer, you have to be sure it's wired exactly as shown.
There may be some menu issues also.
« Last Edit: May 26, 2013, 08:51:35 PM by K7KBN » Logged
Pat K7KBN
CWO4 USNR Ret.
W5CPT
« Reply #4 on: May 27, 2013, 05:27:44 AM »
I use the same keyer into an Icom IC-756.
The input to the Keyer for your paddles is the Stereo Phone Jack marked "Key Input".  The output of the keyer, an RCA jack labeled “Keying Output” is wired directly to the radio input a ¼” mono phone plug marked “Key” through an adapter.
What most likely is causing your malfunction is the setup of the keyer.  I would check the Weight parameter – page 10 of your manual.   The keyer that preceded my 495 was a 452 and I had a very similar problem when I first installed it.
Clint – W5CPT -
« Last Edit: May 27, 2013, 05:31:22 AM by W5CPT » Logged
W8PO
« Reply #5 on: May 27, 2013, 08:22:12 AM »
Thanks for the hints guys......cookout for all today so won't have time to mess with it. Hope you all have a great Memorial Day.
