Author Topic: Yaesu VX-5R Altimeter  (Read 3292 times)
W1AJO
« on: May 26, 2013, 05:57:52 PM »
I have the SU-1 Altimeter for my VX-5R.  I've had it since around 2004 but never really used it.  Today I was at the beach in the Tampa FL. area and tried adjusting it.  No matter how I set the offset I could never get it to work correctly.  The readings vary widely.
I hard reset the VX-5R this moring.  At sea level the VX-5R read 25 meters.  With an offset of -25 it reads 8 meters,  With an offset of 32 it reads -11 meters then 12 meters.  I set it back to -25 and it reads 16 meters.
This thread says it's junk:
http://www.eham.net/ehamforum/smf/index.php?topic=48613.0
I guess I've confirmed it.  I can't find any specifications for it.  Anyone know what the accuracy is *supposed* to be?  You would think that if it is off by 25 meters the adjusted offset would bring it back in range.
KB4QAA
« Reply #1 on: May 29, 2013, 08:59:19 AM »
As an aviator, I wouldn't expect accuracy  closer than a few hundred feet, at best. Even the cheapest mechanical aviation altimeters cost hundreds of dollars.
