Author Topic: Bend chart for 3/8" aluminum tubing  (Read 6715 times)
KD5GR
« on: June 03, 2013, 07:17:21 AM »
A friend and I are building 2-meter LFA yagis and are having a hard time making the end pieces for the driven element loop.  The bends aren't coming out the right size in terms of spread; i.e. keeping the two driven elements correctly spaced.  Here is a link to the LFA loop design.  http://www.g0ksc.co.uk/making-the-lfa-loop.html   We've tried the method shown, but it doesn't work, the end piece is too short.  We've added the depth of the 3/8" slot on the bender (approx. 3/8") and the end piece is too long.  If we have to, we'll just stay with the trial and error method, but a bend charge would sure speed up the process and save material.
This is the bender we are using:  http://www.lowes.com/pd_331956-943-66575.UPP5_0__?productId=3228222&Ntt=tubing+bender&pl=1&currentURL=%3FNtt%3Dtubing%2Bbender&facetInfo=
Does anyone know of a bend chart showing the set back for tubing this small?  I know they are available for conduit, but I can't find one on the Internet for tubing.
Chas.
« Last Edit: June 03, 2013, 07:40:23 AM by KD5GR » Logged
« Reply #1 on: June 03, 2013, 08:48:13 AM »
Or you could bend the corners then splice them to straight lengths for the
sides of the loop, making adjustment much easier.
K2CUB
« Reply #2 on: June 03, 2013, 11:51:34 AM »
Google Aircraft mechanics handbook and tube bending.  There are many resources in this arena for bending tubing and setbacks.  Also google 43.13 aircraft mechanics handbook and FAA to download a copy.  I believe they are in there also.  Hope this helps.  73
KD5GR
« Reply #3 on: June 03, 2013, 01:48:42 PM »
Thanks for the help guys.
Chas.
KD5GR
« Reply #4 on: June 03, 2013, 01:49:32 PM »
This would be easy and it would allow us to easily adjust the spread between DE1 and DE2.
Thanks Dale,
Chas.
KW6LA
« Reply #5 on: June 06, 2013, 04:30:06 PM »
I have bent more than my share of tubing and WR-xx waveguides. Bend charts are only a start and you learn how your tool reacts on different material and or radii. The speed in which you fold the bend, one to
the next can change things. You will need to over bend for spring back also. Now you go into learning mode ? Is it long or short ? Add or substract as required and use small pieces to perfect the bend with the tool
you are using. Use paper or plywood to draw up a 1:1 template to check your work. Use a pencil to mark the tube as a reference to the bender to be consistent. Never scribe lines for it will crack upon bending.
The tool you have is fine, however I build my own jigs with rollers in each corner. What happen is the tube wants to pull away from it position on the following bends. Now the chart is useless. With a little practice
you will learn the art of bending. Good Luck !
KW6LA
« Reply #6 on: June 06, 2013, 04:42:03 PM »
Oh BTW.. the best of the best benders would have a difficult time folding a rectangle with a perfect match end to end. Bend it long, so you have a overlap to cut off for a match. 3/8  tubing will easily over lap
so you can hacksaw it off. The best secrets in sheet metal / bending is how to cheat ! !
KD5GR
« Reply #7 on: June 07, 2013, 05:46:44 PM »
I'm convinced that Dale's suggestion is the way to go.  I'll bend the ends, then put them into a 1/2" piece and adjust for proper element spacing at the ends of DE1 and DE2.
Chas.
