Author Topic: I'm now running a QRP station - FINALLY!!!  (Read 12904 times)
KA0HVE
« on: June 29, 2013, 07:40:07 PM »
I've been off the HF bands for years.  I got psyched up after attending Field Day with a group of guys.
I cranked down a recently purchased Ten-Tec Century 21 and I'm feeding it into a W3EDP antenna.  First contact was about 273 miles at about 2 1/2 watts.  I'll take it.  Now that I got a couple of kinks worked out of my station I'm running about 5 watts.
CW at QRP power is a blast so far.  I've been wanting to do this for years.  Like I said, FINALLY!!!
NU4B
« Reply #1 on: June 30, 2013, 04:45:46 AM »
Congratulations! The Century 21 is a fine rig. I think you'll find that 273 mile QSO just the beginning of many enjoyable QSO's. Good luck!
W7ASA
« Reply #2 on: June 30, 2013, 10:27:05 AM »
Great!  That Century 21 is quite a good CW rig, nice sounding and it's possible to repair it, either yourself or through Ten Tec.
>Ray
W7ASA ..._ ._
KA0HVE
« Reply #3 on: July 01, 2013, 07:14:45 AM »
For portable use I eventually want to build a QRP xcvr.  Any suggestions for a first kit to build (xcvr or other)?
W1JKA
« Reply #4 on: July 01, 2013, 08:27:57 AM »
Re:KA0HVE
A lot depends on TYPE of portable ops that you intend to do. For typical sunny patio/park picnic table weekend ops the relatively larger and more fragile rigs like a K-1 or Weber tri bander are ideal. For more exposed rough and tumble ops like backpacking, operating from canoe/kayak, the smaller and rugged single band rigs like the MFJ Cubs are better suited. Experience quickly taught me to leave my K-1 at home or at most a nice sunny day portable out in the back yard screen house.
« Reply #5 on: July 01, 2013, 12:27:21 PM »
Quote from: KA0HVE
I really like the SW40+ series for backpacking:  small, cheap, light, and easy to use.
After hauling my old Argonaut (which is light but takes up a lot of space) and HW-8 around
in my backpack I found that, even with multiple bands available I mostly worked 40m anyway.
I've tweaked the receive current down below 30mA so it is fairly stingy on battery power,
which helps to reduce the total weight.
K6TTE
« Reply #6 on: July 01, 2013, 01:54:03 PM »
How about a NorCal 40a?  It was my first kit and I managed to make it work.  The kit was top notch and not too difficult to build.
« Reply #7 on: July 01, 2013, 06:53:29 PM »
How about something nice like an Elecraft K1?
F8WBD
« Reply #8 on: July 02, 2013, 02:14:52 AM »
Great rig the Century 21. Had a new analog version many years ago. Don't forget the OHR series of mono-band QRP kits.
K0OD
« Reply #9 on: July 02, 2013, 04:32:59 AM »
Could anything be easier than this for a first transceiver kit? Incredibly low parts count.
http://www.eham.net/ehamforum/smf/index.php/topic,88638.0.html
KA0HVE
« Reply #10 on: July 07, 2013, 10:34:01 AM »
I'm still getting used to QRP.  Iowa to Maryland using 5 watts and a marginal antenna!  Incredible.
WB8YYY
« Reply #11 on: July 27, 2013, 07:02:01 PM »
Fine on your operation with the Century 21.  Since you expressed interest in building a QRP, here are a couple recommendations --
1. Single Band 40m -- Cyclone from 4 State QRP Club.  Nice performance and excellent support during build.  Rig is about same size as a paddle, 5 watts output and tunes entire CW band.  Stable after short warmup.
2. PFR-3 or Hendricks Tri-Bander from QRPkits.com -- these are multiband rigs, a bit more complex.
If you don't have prior soldering experience, I suggest a simple warm-up project -- 4 state QRP has a nice electronic keyer for example, or a nifty NESCAF audio filter from NE QRP club.
73 Curt
KA0HVE
« Reply #12 on: July 31, 2013, 11:52:16 AM »
The Cyclone sounds really good according to some reviews.  I wonder ...   Grin
AK4YH
« Reply #13 on: August 01, 2013, 02:18:10 PM »
Hello,
I'd suggest a KX1 because of the DDS VFO. You can't go wrong with any Elecraft kit.
The KX1 can receive short wave broadcasts as well, which the K1 can't.
I have a K1 and I love it. A bit drifty while warming up, but stable after 10 mins.
The advantage of the K1 is slightly more power, a better ATU and a speaker.
Gil.
KK0G
« Reply #14 on: August 02, 2013, 07:32:59 AM »
Hi Dan,
Glad to hear you finally got that old Ten-Tec on the air. Let me know if you want to set up a sked sometime. 73
Chris
