Author Topic: Question about Field Day log reporting  (Read 3100 times)
KU4UV
« on: July 01, 2013, 11:52:38 AM »
I hope this is the correct forum for this question, and that someone can help me out.  My brother and I are both ham operators, and we operated Field Day a few weeks ago.  I did all of my logging electronically, and I think I have sent everything to the ARRL that they will need for our entry.  I used the http://www.b4h.net/cabforms site to enter all of our information.  My question is this, do I still need to turn in a log of all of the stations we worked by callsign, or will the Band/Mode list that I entered on the above website be all that the ARRL needs for our Field Day entry?  I plan on e-mailing supporting documentation such as the Field Day bulletin copy to the ARRL, but I wasn't quite sure if they still need a list of the callsigns of the stations that we worked during FD, or just a breakdown of how many stations we worked by Band/Mode.  Can anyone help me on the answer to this one, as it has been a while since I last did Field Day.  Thanks!
KU4UV
WH7DX
« Reply #1 on: July 01, 2013, 01:38:45 PM »
KU4UV
Google field day arrl rules 2013.
Section 8.
Complete the form which you did.   Now email log or mail paper log.   You'll email etc.
KB3LIX
« Reply #2 on: July 01, 2013, 02:10:54 PM »
I use N1MM as my logging program.
The rules state that they want a dupe sheet listing all
the calls worked. HOWEVER, I have not figured
out how to output a dupe sheet.
So I generate a Cabrillo File log and send it to them
along with the Field Day message.
Iffin it works...GOOD
Iffin it don't...Oh well, better luck next time.
Seems like I did the same when I last worked FD back in 2011
and it worked.
K5TR
Administrator
« Reply #3 on: July 02, 2013, 10:29:45 AM »
http://www.arrl.org/files/file/Field-Day/2013/2013%20Rules.pdf
Also from section 8 of the rules this year:
8.7. Cabrillo format log files are not required for Field Day entries. They will be accepted in lieu of
the dupe sheets but do not substitute for a summary sheet.
So I think you are good to go.
George
K5TR
