Author Topic: Yaesu FT2000 LOST CAT connection???  (Read 4194 times)
NE5C
« on: July 14, 2013, 08:59:45 AM »
Rig stopped connection up to Ham Radio Deluxe few weeks back! PC Ports seem to be fine, If I use the HRD Cat Commands tester, Rig will respond with CONNECTED, but will not answer to any commands, just replies with ERROR?Huh Well How bad is this? any advice? Cables tested, I am just left thinking it is something in the radio cat interface?Huh any advice, God Bless and 73, DE N5JFJ, Jerry Shocked
NE5C
« Reply #1 on: July 14, 2013, 09:10:22 AM »
PS; Fellow radio friends, I have done a Master Reset, to the Rig and found that this did not help me either!!!! I forgot to say that earlier...HELP??? ANY ONE??? ADVICE???
N4ATS
« Reply #2 on: July 14, 2013, 01:56:08 PM »
Check R3004 and R3005 for zero ohms, Typical , then if OK replace Q3055 (ADM3202ARU)
« Last Edit: July 14, 2013, 02:02:38 PM by N4ATS » Logged
NE5C
« Reply #3 on: July 14, 2013, 03:06:18 PM »
Thank you Sir for your advice I certainly appreciate it.
TA2ST
« Reply #4 on: June 20, 2016, 03:01:16 AM »
Hello NE5C,
I wonder did you solve your FT-2000 cat connection problem. Now i have same problem with my FT-2000.
i am waiting for your answer. Regards TA6AX 73
