Author Topic: Help me compare these two power amp transistors  (Read 13089 times)
« Reply #15 on: July 23, 2013, 04:06:04 PM »
If you do that, you should use the same source's transistor for the other side, Complementary Pair and not the original.  So find the BD 437's complementary PNP and order it up as well, for the other side.
Doubtful the amp is being pushed all that hard in this application.
KE4JOY
« Reply #16 on: July 23, 2013, 04:59:00 PM »
No the amp is not pushed hard at all, frankly I wondered about the 40watt requirement. Would probably rip the speaker to shreds.
So the BD437 & BD438 looks like a good pair?
http://www.st.com/web/en/resource/technical/document/datasheet/CD00000910.pdf
« Last Edit: July 23, 2013, 05:02:40 PM by KE4JOY » Logged
« Reply #17 on: July 24, 2013, 07:01:53 AM »
Any amplifier is nothing more than a modulated power supply.
Therefore the actual power output of any amplifier is limited by whatever amount of power its power supply can deliver.  In this case, that would be the combined power of the two DC rails, minus the Efficiency factor of the amplifier design type.  Amplifier design type (or class) is what the power dissipation spec brings to the subject.  Bear in mind that this figure is NOT the same as "power output capability" -- it refers to how much power, in heat, that the device can safely dissipate without destroying itself.
KE4JOY
« Reply #18 on: July 24, 2013, 10:44:14 AM »
Understood, I must give many thanks for your help and patience with this.
Parts are on order, sure to miss that receiver puts my tube rig(s) to shame  Cheesy
