Author Topic: will the turbo tuner for icom radio work on ic7000?  (Read 3126 times)
N1JAO
« on: July 25, 2013, 06:35:51 PM »
hello,
I had a 746 pro with the little tarheel antenna and turbo tuner on my rv and worked great. I sold the 746pro and bought the ic7000. turbo tuner shows two models on their website one for icom and one for ic7000. will the turbo tuner for icom radio work on ic7000? if you have specific experience with this situation please help. thank you in advance.
bob
n1jao
M6GOM
« Reply #1 on: July 26, 2013, 06:27:01 AM »
Email Alan K0BG. He is the most likely to know.
K3GM
« Reply #2 on: July 30, 2013, 04:49:36 AM »
Bob, here's my recollection regarding the Turbo Tuner being used with the 7000.  The TT gets its power from the IC-7000.  The PC board trace which supplies the voltage is not wide enough to supply the current demand of the TT and the screwdriver motor.  The result is eventual failure of that trace.  I took heed of that warning when I was looking for a controller and went with a Better RF unit which does not use the accessory 12V from the radio.  Again, this is my recollection.  I believe there is more information on the K0BG site regarding this.
