Author Topic: Mobile Install Question  (Read 7340 times)
APW19562
« Reply #15 on: July 31, 2013, 09:24:38 AM »
Do you test it with the engine running ? or not ?
If it does it with the motor running, you might have a bad diode in the alternator. That will put AC voltage into your DC electrical system.
Had this exact same problem on a 2000 Ford Expedition.
N6DSR
« Reply #16 on: July 31, 2013, 11:30:55 AM »
Art, every time the fuse has blown, the engine has been off.
« Reply #17 on: July 31, 2013, 12:46:21 PM »
What is the radio touching when the cable is connected?  Is the antenna connected?  Sure is starting to sound like a bad negative battery cable or ground.  Is there a chance this is a positive ground jeep?
N6DSR
« Reply #18 on: August 01, 2013, 06:26:00 AM »
Only thing the radio is touching is the mounting bracket
and yes the antenna is connected.Odd thing is when I mounted the cb into the Jeep
I didnt have any problem.
In fact, the radio is mounted in the same place as the cb was.
N2MG
Administrator
« Reply #19 on: August 01, 2013, 10:58:51 AM »
Still haven't answered my previous question (post 14)
Have you tried testing with NO radio plugged into the power cable?
N6DSR
« Reply #20 on: August 02, 2013, 06:52:44 AM »
Gentlemen, I appreciate all the replies.
I think that old age is responsible for the error I was having getting the rig installed.
Yesterday, I went out to conduct some of the tests that
were mentioned here and found out that it was an operator error
in the first place.
I found that I had indeed been trying to hook the wrong cables to the wrong posts.
I felt like such an idiot.
Ran the wires and it now works.
Thanks again.
73 K7UTA
donnie
« Reply #21 on: August 02, 2013, 11:56:10 AM »
You were just making sure the reverse diode was working as it should.
K1CJS
« Reply #22 on: August 03, 2013, 08:13:33 AM »
Selective reading--or skimming.  Mine (#11) was also ignored--even though I tried to be polite about it.
N6DSR
« Reply #23 on: August 03, 2013, 08:27:06 AM »
Sorry, I didnt ignore it.
I did and nothing happened.
K1CJS
« Reply #24 on: August 03, 2013, 01:03:29 PM »
Then I offer my humble apologies. 73.
