Author Topic: importing N3FJP adif into HRD logbook  (Read 5923 times)
KG8JF
« on: August 02, 2013, 06:01:35 AM »
In logbook when I click on logbook, "Import>>>adif" I get a drop down that is partially grayed out and won't allow me to write in the location of the file I want to import.  Anyone have any suggestions?
K4EZD
« Reply #1 on: August 02, 2013, 11:26:48 AM »
In the space where it says "adif filename"  click on the little box that has the three dots. Then when a new box will appear that says "load adif file" and just type in the file name on the bottom line indicated.  Should work if it the software is not defective.
KG8JF
« Reply #2 on: August 05, 2013, 04:17:26 AM »
I do not see what you are talking about.  I am looking under, "Logbook", about halfway down I see, "Export", "import".  I click on import and get what I have mentioned.  I do not see the three little dots.  I am using ver 5.22.
K3DCW
« Reply #3 on: August 05, 2013, 08:58:58 AM »
Do you already have a log file opened in HRD Logbook?  If you are attempting to import an ADIF file, you need to have a log file already opened in HRD so that it knows where to import the ADIF data.
If this is a brand new log file, then simply create a new log file in HRD Logbook (File, Open Database, Create New Database), and then go through the steps to import the ADIF file.
Dave
K3DCW
Hamming it up on OS X!
www.machamradio.com
