Author Topic: PSK  (Read 2101 times)
KE4HGP
PSK
« on: April 13, 2003, 08:08:24 PM »
I am having problems setting up PSK,i have an icom 718 with an Rascal Mark V Interface.I am using Win Psk.
The problems i am having are that when i hook up the serial port connection the radio stays keyed,i tried fixit,but not sure if i have install fixit properly.Any help on this would greatly be appreciated.
Thanks
Tim
KE4HGP
KG4RUL
PSK
« Reply #1 on: April 14, 2003, 09:18:06 AM »
Unfortunately, I too have a RASCAL!  You know, it is interesting that the logo is a Raccoon and, Raccoons wear masks!  After you buy one of these, you feel as though you have been robbed.  Mine is for a Kenwood TS2000X and it has the same problem!
How do you spell Junk? B U X C O M
Dennis - KG4RUL
KE4HGP
PSK
« Reply #2 on: April 14, 2003, 10:05:02 AM »
I hear that,are you running windows xp?What type of interface are you using now,i am just not impressed with this product.I had packet up and running on the same serial port with no problem.Dont understand why The RASCAL MARK V will not work,is it possible that its defective or junk?
Thanks
Tim
KE4HGP
KG4RUL
PSK
« Reply #3 on: April 14, 2003, 10:58:51 AM »
I am running WIN98 SE.  My current interface is homebrew and I use it for PSK, WSJT, etc.  I use the built-in TNC on the TS2000 for Packet and APRS.
Junk: something of poor quality : something of little meaning, worth, or significance
Dennis - KG4RUL
WB8ROL
PSK
« Reply #4 on: April 15, 2003, 10:20:33 AM »
I have a Rascal MKV interface (and cables for 2 rigs) AND my brother has a MKV also .... while they are convenient and work well here ALL 3 had to have the microphone plug going to the rigs rewired.
The interfaces are fine -- but the Rascal people just are NOT wiring the mike plugs correctly.
Out of the box all 3 were incorrect and kept the respective rigs keyed.
At least they DID send the right mike plug BUT either their wiring info is all wrong OR the people/person who wire them nee to be sent to Iraq ...
KE4QCI
PSK
« Reply #5 on: April 19, 2003, 11:51:52 PM »
I have a laptop with no serial port only USB, running win XP. I bought a USB to serial cable to connected to my IC 718 with nomic rigblaster to work on PSK but this setup won't work correctly because it kept keying my radio. Please help...I did try a lot of things without success. Thank you.
DA1TNJ
PSK
« Reply #6 on: May 05, 2003, 10:15:23 AM »
I believe your problem is the wiring to the
opto isolator.  I have a Rascal soundcard
interface which originally was wired for
my Drake T4XB.  I rewired the plug from a
stereo phone plug to an RCA and it works
just fine with my Yaesu FT-767GX.  The
reason your rig is being keyed is incorrect
polarity from the opto-isolator to the rigs
keying circuit.  Try reversing the wiring to
the rigs PTT circuit and I'll bet it will
work.
Michael
