Author Topic: Softrock Ensemble RX II  (Read 2640 times)
KC9QQM
« on: August 19, 2013, 07:47:39 PM »
Hi all,
I have had this SDR for a while (I use HDSDR with it) and I noticed something that probably has been going on since I made it. The frequency waterfall is mirrored around the LO. I can receive the same transmission above or below the LO and just have to change the SSB type if that is the mode i am using.
Any ideas? Sounds ok, AM, CW and SSB all work and tune ok but even though the frequency shows correctly a the mouse or the line under the waterfall the reception is just a repeat of what is below the LO.
Jeff
KC9QQM
KC9QQM
« Reply #1 on: August 20, 2013, 08:54:03 AM »
Got it figured out with some help, The cable I was using to bring the I and Q from the Softrock to the computer had one of the channels missing. Replaced it with a good cable with both L & R and all is ok.
Jeff
KC9QQM
