Author Topic: HeathKit HG-10 VFO Dial Tube replacment any where?  (Read 3453 times)
KH2BR
« on: August 20, 2013, 08:03:44 AM »
I am in a kind of a fix right now, and need to find a replacement for the VFO Tube dial in my HG-10 VFO. The tube is badly
cracked and I have been looking on ebay for some time and nothing has come up. I did get one in the past from Ken, KE4MG
but he no longer makes them and does not have supplies to make another one.
    Does anyone have a source for these dial tubes, or know how to make them. With fingers crossed, This is
Robert KH2BR
AD4U
« Reply #1 on: August 20, 2013, 10:53:40 AM »
The ONLY source is a parts VFO.  To minimize your cost try to find one with a nice dial tube, but rough otherwise.
Dick  AD4U
KD0REQ
« Reply #2 on: August 20, 2013, 11:30:42 AM »
if you were to very carefully take the dial glass tube off, and roll it with the light on a copy machine plate, and copy that master to a clear acetate or Mylar sheet, and wrap that around a plastic tube of the right diameter, you'd be close enough for amateur work.  don't attempt in any way to remove the metal plugs or axle, just roll and pray.  or a scanner plate, where you can see the reader move and roll with it, newer copy machines zip by too fast.  McMaster-Carr online should have the plastic.
glass is a colloid and considered a "statistical material" in architecture, I am told, and the consideration of skyscraper glass is not "can it break," but "can we manage breakage so nobody dies."
« Last Edit: August 20, 2013, 11:32:51 AM by KD0REQ » Logged
W9GB
« Reply #3 on: August 20, 2013, 02:04:56 PM »
K9STH has the dial drum scale.
http://www.k9sth.com/uploads/dial_drum_ad-1.pdf
IF you need the tube itself, you could ask Glen.
Clear plastic mail tubes, plastic, acrylic, or polyethylene could be considered.
VisiPak
http://www.visipak.com/
ClearTec Packaging
http://www.cleartecpackaging.com/
TAP Plastics
http://www.tapplastics.com/product/plastics/plastic_rods_tubes_shapes/clear_acrylic_tubes/141
ULINE
http://www.uline.com/BL_3651
Bath Salt Tubes (PET)
http://www.sks-bottle.com/BathSalt-Containers2.html
HOBBY LOBBY and Model building stores
« Last Edit: August 20, 2013, 02:13:43 PM by W9GB » Logged
KB4QAA
« Reply #4 on: August 23, 2013, 09:09:33 AM »
www.radiodaze.com
Has added the capacity to make replacement dials recently.  You might call them and discuss your needs.  They are a reliable vendor located in upstate NY.
