Author Topic: Alinco DJ-V27T  (Read 11403 times)
N2SDB
« on: August 22, 2013, 06:25:11 AM »
Hello,
I have no audio on my Alinco DJ-V27T radio. This just started. I do have sound when I hit the Monitor key...and I do hit the repeater and hear it coming back on my mobile radio (Alinco DR-235)..I checked all setting and they seem to be correct.
Is there something wrong with the radio all of a sudden?
Any ideal??
Please advise..
ciuppap@optonline.net
Paul D. Ciuppa
N2SDB
« Last Edit: August 22, 2013, 06:27:56 AM by N2SDB » Logged
K4JJL
« Reply #1 on: August 22, 2013, 07:54:26 AM »
RX PL Tone enabled/disabled?
KE3WD
« Reply #2 on: August 22, 2013, 08:40:45 AM »
Flotsam, jetsam or dirt on the internal switch contacts of the earphone jack?
Insert and remove any plug that fits the earphone jack several times, with the radio power turned off to preclude possible wrong connections, then turn radio on and check speaker operation.
N2SDB
« Reply #3 on: August 22, 2013, 09:27:56 AM »
No DCS or RX PL on and tried the earplug trick and still nothing...I even reset the radio ...so strange ... Huh And no response from Alinco either...
KE3WD
« Reply #4 on: August 22, 2013, 04:13:30 PM »
See if you can hear using earphones or another speaker in the jack.
If not, and if a full reset doesn't do it, suspect a fault in the radio itself that needs to be troubleshot and repaired.
K4JJL
« Reply #5 on: August 23, 2013, 08:47:05 AM »
Does it have a squelch knob or is it an e-pot (menu setting)?
KG6BRG
« Reply #6 on: September 04, 2013, 05:25:17 AM »
Try transmitting to the radio with the DR-235 on simplex.  Do you see any S meter deflection, but still no audio?
Alinco moved their warranty service recently to another outfit.  Have you contacted them, or Alinco?  I've dealt with Alinco's authorized service center in the past and had good service.  Good luck.
KQ6Q
« Reply #7 on: September 17, 2013, 01:42:18 AM »
the squelch setting may have gotten changed - read the manual, and try adjusting the squelch from the keypad. since the monitor button opens the squelch, that's your biggest clue...
