Author Topic: N3FJP Amateur Contact Log  (Read 4937 times)
KG8JF
« on: August 24, 2013, 09:58:01 AM »
When I I click on the button that says, "all contacts not uploaded",  I get a message that says file not found.  I have station location and the path to TQSL entered correctly after quadruple checking.  I have checked with Scott and his plate is probably full at the moment.  Anyway, I am in need of some assistance to upload QSO records to LOTW.  Thanks
KG6AF
« Reply #1 on: August 24, 2013, 11:22:06 AM »
I've found that LOTW uploads work a lot better from inside the N3FJP logger now that I've upgraded to the latest log version (4.1) and the latest version of TrustedQSL (1.14).  The upgrade from pre-4.0 versions of the logger isn't automatic (you have to export contacts from the previous version and import them to the new version, and re-enter your customized settings), but it was worth it.
Both upgrades are free.
KU4UV
« Reply #2 on: September 07, 2013, 08:12:14 PM »
I am getting the same error message, even after upgrading to the latest versions of both ACLOG and TQSL.  Post an update on here after you find something out from Scott.  It is probably a simple fix.  Thanks!
Mike KU4UV
