Author Topic: Tar Heel Antenna Model 100 Question  (Read 10508 times)
KA4NMA
« on: August 28, 2013, 08:48:58 PM »
What are the differences between a "second generation" Model 100 with the current model?
Randy ka4nma
KA4NMA
« Reply #1 on: September 01, 2013, 06:27:06 PM »
766 views 0 replies?
WD5GWY
« Reply #2 on: September 01, 2013, 07:10:41 PM »
I'm one of the 766 views. The reason I had not replied was because I have not used
the older Tarheel 100. I had (traded it recently) a 100a HP and overall, it was a decent
antenna. I still have a 200a HP and it works quite well. It has the taller mast and puts
the coil above the cab of my pickup. The 100a HP had the shorter mast and, "I felt" that
having the coil a bit below the level of my pickup's cab, hindered performance . Not much,
but, I do think the 200a is better.
   I have seen the older generation of 100's at hamfests and just looking at them, I see no
difference between them and the one I had. If it is anything, it is probably an improved drive
motor. I would suggest you call Tarheel Antennas Tuesday and ask them. That way, if you are
thinking about buying a used 100, you will have better information to go on.
Good luck. The Tarheel antennas are decent antennas. But, like anything else, good performance
depends heavily on your installation.
james
WD5GWY
Oh, have you looked at the REVIEWS section here on eham? You might find your answer there. But,  you will have to sift thru several pages of reviews to get to it.
N5UD
« Reply #3 on: September 12, 2013, 03:09:52 AM »
From fuzzy memory:
One of the differences is the motor. The original used a high current motor. It won't work with most controllers.
The motor runs great from your toggle switch.
73 Tony N5UD /M
KE4DRN
« Reply #4 on: September 12, 2013, 06:49:08 PM »
hi,
You can email Robert NC4RY with any Tarheel Antenna questions.
http://www.tarheelantennas.com/tech_info
73 james
