Author Topic: Ft60r Charger?  (Read 26464 times)
KJ6MIV
« on: September 12, 2013, 09:20:49 PM »
For the life of me I cant find my ft60r charger. I looked at buying a replacement and it seems like they are around $30.  Do I need to buy one of these $30 chargers or can I go down to radio shack and buy a charger for $10?  If so what do I need to properly charge my ft60r?  Thanks,
John
KB1LKR
« Reply #1 on: September 12, 2013, 09:39:44 PM »
Any 12 VDC 200 mA supply should do the job. Not sure which is pos. terminal or its diameter though.
N3HFS
« Reply #2 on: September 13, 2013, 05:32:37 AM »
Yaesu's part number for the simple cable (bare ends to barrel connector) is the EDC-6.
The barrel end is 4.0mm/1.7mm, and should be wired center-positive for the FT-60.
If you have a Radio Shack handy, this connector is what you want:
http://www.radioshack.com/product/index.jsp?productId=2102598
KB1LKR
« Reply #3 on: September 13, 2013, 09:44:25 AM »
BTW 13.8 VDC will work too, a cigarette lighter plug could be used to charge it if needed.
K6LCS
« Reply #4 on: September 13, 2013, 11:04:06 AM »
If you would like the convenience of automatic charging - and many more discharge-charge cycles from your stock NiMH pack - you may want to consider an intelligent, drop-in charger. Like what BatteriesAmerica.com offers ...
EMS-57-83    Desktop Rapid Charger - for both NiCd & NiMH batteries.
Charges battery alone, OR you can insert the entire HT.  FAST /
SMART / EASY TO USE !  Fully automatic; no buttons to push.  Charges
battery swiftly, then shuts down to trickle charge when battery is full.
Includes worldwide AC-DC wall power supply (100-240VAC input).
http://www.batteriesamerica.com
Clint Bradford K6LCS
Clint Bradford, K6LCS
http://www.work-sat.com
N6AJR
« Reply #5 on: September 14, 2013, 12:44:52 PM »
I agree with k6lcs.. best way to go.
