Author Topic: Diamond antenna help  (Read 5012 times)
KJ6AKA
« on: October 03, 2013, 05:06:54 PM »
I ordered and have the Diamond NR770HAB ant.I also ordered the adapter at Universal radio (the link below).I assumed that the feed would screw on like the PL259 does with the antenna itself.But it looks like I'll have to solder the coax into the metal stem of this adapter.Now I have in the past made jumpers for HF with installing PL 259 connectors....but have never soldered to this adapter before.Can someone please show me how this done.
Thanx in advance
W6DLB
http://www.universal-radio.com/catalog/hamantm/2210.html
K6LCS
« Reply #1 on: October 04, 2013, 08:16:29 AM »
There's no coax in this "equation." Did you consider the Diamond C213SMA Cable Assembly?
Clint Bradford, K6LCS
http://www.work-sat.com
M6GOM
« Reply #2 on: October 05, 2013, 09:56:27 AM »
Thanx in advance
W6DLB
OK look at the main bit, L shaped bit the antenna screws on to. At the opposite end of the main tubular shape to the end the antenna screws onto there is a cap you need to remove and in the middle once you've removed the cap you'll see the centre pin. To prepare the coax you strip back about a third of an inch or so of the outer braid and insulation, folding some of the braid back over the outer insulation, leaving the 1/3 inch of insulated centre of the RG58 protruding. Strip just a little of that off and tin the centre wire. Feed it into the tube coming out the side and solder the centre of the coax to the centre pin. Replace the cap.
KJ6AKA
« Reply #3 on: October 05, 2013, 04:00:40 PM »
Thanx in advance
W6DLB
Thanx much...that worked out ok.
