Author Topic: Undercoating  (Read 3915 times)
K3GHH
« on: October 13, 2013, 06:18:03 PM »
To connect coax to a bumper mount, the center conductor and braided shield are separated and each soldered to a lug, with the center lug screwed to the base of the mount and the braid to a convenient nearby ground screw. Is it safe or advisable to spray this assembly with black rubberized undercoating? Is there a better way to protect those bare wires from corrosion?
--John K3GHH
K1CJS
« Reply #1 on: October 14, 2013, 05:11:09 AM »
As long as the mechanical connection isn't sprayed before it's made and tightened, It's OK to do that--just make sure the undercoating is NOT conductive before you do it!
KG4RUL
« Reply #2 on: October 14, 2013, 05:23:18 AM »
To add to that, make absolutely sure that you get complete coverage.  Any pinholes will allow moisture to get in which is then trapped.
