Author Topic: Power Problem  (Read 14614 times)
K1CJS
« Reply #15 on: November 12, 2013, 04:55:32 AM »
Another thing to check is the fuse holders.  Yes, the in-line fuse holders supplied by the manufacturer.  Fuses alone due to their nature will produce a minute voltage drop, but if the fuse holder clips are loose or dirty, (or the ends of the fuse are dirty/corroded) the voltage drop may well be large enough to show the results you see.
At the same time, check the power plug/socket on the rig or its power harness.  A loose/dirty connection at that point is just about as bad.
« Last Edit: November 12, 2013, 04:57:59 AM by K1CJS » Logged
