Author Topic: Motorola Netopia® 2247-62-100T ADSL2+ Gateway  (Read 9860 times)
W9GB
« on: November 03, 2013, 08:44:26 PM »
Quote from: AC5UP
... shut it down for dinner then came back to it.
May have been required for your ISP "reset" or configuration reboot of 2247 firmware.
Motorola Netopia® 2200 Series ADSL2+ Gateways
http://www.motorolasolutions.com/web/Business/Products/Wireline%20Networks/Gateways%20&%20Routers/DSL%20Gateways%20&%20Routers/2200%20Residential%20Series/_Documents/Static%20Files/2200%20Series%20Data%20Sheet%20541635-001-c.pdf
Motorola Netopia® 2247-62 ADSL2+ Specification Sheet
10NA: Designation for North American Version.  20EU: Europe.
http://www.motorolasolutions.com/web/Business/Products/Wireline%20Networks/Gateways_and_Routers/DSL_Gateways_and_Routers/2247-62Netopia/Documents/Static_Files/2247-62%20Netopia%20ADSL2+%20Wi-Fi%20Gateway.pdf?pLibItem=1&localeId=33
Motorola Netopia® 2247/57-62 DSL Gateway : User Manual (2008)
http://www.netwood.net/support/manuals/Netopia2241N-VGx-UserGuide.pdf
Administrator's Handbook, Version 7.8.2 (Jan 2009)
Motorola Netopia® 2200, 3300 and 7000 Series Routers : Residential models
http://www2.gtconline.com/wp-content/uploads/2012/05/2247-62-10NA_AdminHandbookV782.pdf
ARRIS Support
http://www1.arrisi.com/Support/US-EN/Consumer-Support/DSL-Modems-and-Gateways
Motorola 2247-62 (2247-62-100T) : Wiki Devi (Aztech mfg.)
http://wikidevi.com/wiki/Motorola_2247-62_(2247-62-100T)
SONIC.NET Wiki
https://wiki.sonic.net/wiki/Motorola_2247-62
192.168.1.1 is a common Gateway IP address for Linksys routers on the wired LAN,
with 192.168.1.2 usually reserved for the Wireless Access Port.
Could have been changed by former owner, installer or ISP image default for their network.
SO, you are saying everything is A-OKAY ??
What version # of firmware did you end up with??  7.8.4r6 ?
Do you have Access to Expert Mode configuration (Admin menu)??
Like Cable Modems firmware (largely unobtainium),
DSL modem firmware is normally downloaded / updated configured from your ISP head-end,
IF they are setup for that service provisioning (TR-069).
DSL CPE (customer devices) are a mixed bag, some ISP controlled, others field setup.
Your DSL ISP must support the firmware version for the Customer Premise Equipment (CPE) -- 2247-62.
Here is a Horror story (LONG) about the 2247 model -- personality changing.
http://www.justanswer.com/computer-networking/7pxow-convert-2247-62-10na-2247-62-100t.html
« Last Edit: November 03, 2013, 09:30:33 PM by W9GB » Logged
AC5UP
« Reply #1 on: November 10, 2013, 01:14:38 AM »
If anyone cares, the Motorola / Netopia DSL Router has been on the web for a week and working quite well. Consistent speed, low latency, and absolutely equal or better than my DSL performance has ever been.
Poked around the router logs last night and found zero bad packets incoming, zero bad packets outgoing, no CRC errors in either direction and a s/n ratio of 30 dB. It may be a while before it wrinkles a packet.
So............. Thanks to W9GB for being a second set of eyes for me on the web and if any of you should see one of these going cheap at a thrift shop:
...consider taking it home. Mine is a keeper. The 22247-62-10NA model is generic and has more bells & whistles in the ROM while the -100T version I have is AT&T Netopia specific but can be re-configured to play nice with Windstream DSL. Just don't believe everything you read in the downloadable documentation about the default IP for the setup utility (do a hard reset then use ipconfig to find it). And don't expect to find any flash ROM updates from AT&T or Arrisi for the 100T version. It has been orphaned. I didn't have the stones to try flashing it with the 10NA ROM (which is available from Motorola) and I can't think of any good reason to do so short of last hope / desperation / gross stupidity. Forcing alien firmware on the 'other' hardware is rarely a plan with a future.
BTW: As a general rule thrift shop goodies do not come with the factory wall wart. Be sure you scrounge up a good substitute. A while back my old router was acting a bit flaky and was cured by a bigger & better wart. Spec for the router was 12vdc @ 600 mils and the wart was rated 12vdc @ 700 mils. In a perfect world that would be OK but an 800 mil wart played better. You'll also find a variety of power cubes and such at thrift shops with a selection that changes on a weekly basis. If you don't find what you need today, stop by the next time you're in the area. They're usually cheap and no better place to stock up on spares.
The end of the world will occur on April 23, 2018 ( the day after Earth Day. Go Figure ).  If you're reading this on April 24th look for updates coming soon.  If you're reading this after June first, fuhgedaboudit.....
W9GB
« Reply #2 on: November 10, 2013, 12:24:42 PM »
Nelson -
So what version of firmware was on this Motorola Netopia® 2247-62 ADSL2+ Gateway ?
Did you get access to the Export Mode, in the Administrative Menu?
Using non-Windstream provided Broadband equipment
https://windstream.custhelp.com/app/answers/detail/a_id/423
I wonder if your Windstream DSL (Internet Service Provider) updates the firmware remotely.
https://windstream.custhelp.com/app/answers/detail/a_id/158/related/1/session/L2F2LzEvdGltZS8xMzg0MTE1NDAwL3NpZC83cTNQSipFbA%3D%3D
« Last Edit: November 10, 2013, 12:38:09 PM by W9GB » Logged
AC5UP
« Reply #3 on: November 10, 2013, 12:37:25 PM »
From the maintenance page:
System Name:  Motorola Netopia 2247-62
F/W Version:  7.8.4r7
DSL F/W Version:  DSP 7.5.2.204, HAL 7.5.2.1
Standard:  ADSL2+
The reference material is (c) 2008 Motorola so I suspect it's not completely obsolete technology... At least not yet.
W9GB
« Reply #4 on: November 10, 2013, 12:44:22 PM »
Great, the latest firmware version that I saw references about was:  7.8.4r6
BTW, the Motorola Netopia 2247 is not orphaned, per se, just technology upgraded.
The current Motorola Netopia 2247-N8 basically adds 802.11(n) support (wireless) and a few other changes.
« Last Edit: November 10, 2013, 12:49:28 PM by W9GB » Logged
