Author Topic: 3-500z  (Read 17401 times)
EI5GUB
« on: November 11, 2013, 02:27:49 PM »
Hi Im thinking of changing the valves in my Heathkit SB-220,what are the best 3-500z valves now,my watt meter is showing around 700 to 800 watts ,can I expect much more with new valves.
AH6RR
« Reply #1 on: November 11, 2013, 03:57:31 PM »
RF Parts in the USA has a good track record on new 3-500ZG's plus a good warranty. There might be distributors in EU that offer Taylor or Greenstone tubes since you are there it might be better to buy local.
W8VVE
« Reply #2 on: November 12, 2013, 05:47:37 AM »
RF Concepts (Alpha amps) sells a matched pair of them for $278 plus shipping.
Here is the website...73...Sam W8VVE
http://www.rfconcepts.com/PRODUCTS/tubes/3-500ZG-Tube-Glass-Triode-Graphite-Anode-Matched-Pair
« Reply #3 on: November 12, 2013, 08:14:30 AM »
With a good pair of 3-500Zs you should get an output of around 1200W.  However, with that being said, note that if you're line voltage is down even a few volts, your output will also be down.
You might consider that when you see a lower than normal power output.
I'm assuming that the drive power hasn't changed.
Al - K8AXW
EI5GUB
« Reply #4 on: November 12, 2013, 02:19:43 PM »
hi thanks for all replies,the plate voltage is 2500 and has never changed in all the time Ive had this amp,what is the difference between 3-500z and 3-500zg
« Reply #5 on: November 12, 2013, 02:23:34 PM »
As I understand it, the ZG has a graphite anode
AH6RR
« Reply #6 on: November 12, 2013, 02:34:43 PM »
The SB-220 should have 3000V on the plate in the SSB position and 2500+/- in the CW position so if yours is showing 2500V in the SSB position then there would be 2 things going on #1 the metering resistors have changed value(most likely) or #2 there is a problem with the HV section though be it small but still a problem and at 2500V you would see 800-900W out so the tubes would still be good. If the HV has changed recently then the HV section needs looking at. The difference between the 3-500Z and the 3-500ZG is the ZG has a graphite anode and the Z has a metal anode.
EI5GUB
« Reply #7 on: November 14, 2013, 04:19:34 AM »
hi again,the metre is showing 2300 volts ssb and 200 cw so its down a bit so,perhaps valves are fine
W8GP
« Reply #8 on: November 14, 2013, 04:34:13 AM »
It's also possible that the voltage is OK and the resistors for the voltmeter have changed value.
« Reply #9 on: November 14, 2013, 04:52:59 AM »
True but point is 3-500z's like 3000 and more on plates for better output and gain and if your supply is soft your output may be down because of that and not tubes.
AD4U
« Reply #10 on: November 14, 2013, 05:45:47 AM »
If your SB-220 has EIMAC tubes, even if they are the original ones, they are probably still OK unless they were abused or used A LOT by a previous owner.  My SB-220 and my L4B are still running the original EIMAC 3-500 tubes and after 40 years they still put out the same power they did when new.
The SB-220 should have HV around 3000-3200V.  If yours only has 2500V, something is wrong.
Dick  AD4u
EI5GUB
« Reply #11 on: November 14, 2013, 11:34:08 AM »
hi yes it has Eimac valves for sure and doesnt get alot of abuse by me or last owner,i fitted a bigger faster fan in it to cool the jugs down,no point changing valves so,no much I can do with power supply either
« Reply #12 on: November 14, 2013, 01:39:08 PM »
I think you have 230V, 50 Hz power there.
Not so sure the SB-220 transformer is rated to operate at 50 Hz, and you may be taking a bit of a "hit" there in efficiency.
« Reply #13 on: November 14, 2013, 07:25:34 PM »
GUB:  My 3-500Zs (Eimac) are 30 years old and still putting out full power.  My plate voltage is 33-3400V.  My plate current runs over 700ma.  When my line voltage drops to below 235VAC then my output drops to 1KW or lower.
Al-K8AXW
EI5GUB
« Reply #14 on: November 15, 2013, 01:21:44 PM »
sorry for delay I have a bad flu etc,yes we have 220 volts here and 50 hz,maybe i will just do with what i have power wise
