Author Topic: 3-500z  (Read 16646 times)
AD4U
« Reply #15 on: November 17, 2013, 06:04:49 AM »
sorry for delay I have a bad flu etc,yes we have 220 volts here and 50 hz,maybe i will just do with what i have power wise
Problem identified, not solved.   Smiley
Dick  AD4U
« Reply #16 on: November 17, 2013, 07:16:12 AM »
you are supposed to have 230volts -6 +10%, although 220 is just in that range. I haven't been able to find out if the SB220 kit supplied in Europe was 'Europeanised' as some Heathkits were: 50Hz, 230/240 volt transformers for example.
« Reply #17 on: November 17, 2013, 07:16:30 AM »
Dick  AD4U
He should be able to get a modern compatible replacement transformer that is 50 hz compliant and has multiple taps for low line voltage for about the price of a pair of tubes.
« Reply #18 on: November 17, 2013, 07:20:22 AM »
Maybe in the US! Over here in Europe, possibly, but I doubt it.
« Reply #19 on: November 17, 2013, 07:36:56 AM »
He could order one from a say even a AL 80b. As long as he did not exceed 1000 watts it should do fine.
« Reply #20 on: November 17, 2013, 02:00:36 PM »
Cheaper would be to get a 10 or 20 volt secondary, 10 amp transformer with a 230 volt primary: put the secondary in series aiding with the input to get 230 to 240 volts. Regrettably, EI land is even more expensive than G or F land, and Lord only knows, we're bad enough!
KC4MOP
« Reply #21 on: November 19, 2013, 03:37:42 AM »
If this amplifier has been yours from day 1 and your line voltage is where it's supposed to be; then maybe it is time for new electrolytic caps in the PS.
I'm guessing that the HV was higher at one time and now it is drifting down?
The proper taps on the transformer are selected?
fred
KC4MOP
« Reply #22 on: November 19, 2013, 04:32:08 PM »
I think you have 230V, 50 Hz power there.
Not so sure the SB-220 transformer is rated to operate at 50 Hz, and you may be taking a bit of a "hit" there in efficiency.
Yup something to think about!  If that linear was shipped from the USA, the transformer is probably 60hz and 50hz is not goodness.
here is a link for running a 60hz transformer on 50hz:
http://www.edn.com/electronics-blogs/powersource/4307945/Specifying-a-Transformer-Why-does-50Hz-make-such-a-difference-
« Reply #23 on: November 19, 2013, 08:18:24 PM »
MOP:  Thank you for that link.  I've always known that a 60Hz transformer would run hot at 50Hz but never knew why!
Which brings up an off topic question:  Why do the Europeans run 50Hz power systems?  Smaller metal stacks in the generators & transformers?
N7BMW
« Reply #24 on: November 19, 2013, 09:07:05 PM »
Because they get to spin their generators at 1500 RPM instead of 1800 as we do in the 60Hz world.
« Reply #25 on: November 20, 2013, 01:32:45 AM »
Motors are more efficient because the eddy currents are less, which is why several railways originally went to 16-2/3Hz, even though more iron is needed. Not so much of a problem these days. Meanwhile, for real standardisation, look at the systems the AMTRAK train from Washington DC to Boston uses. Washington DC to NYC is 12kV, 25Hz. NYC to New Haven is 12.5kV 60Hz, and New Haven to Boston is 25kV 60Hz.
I don't know if the SB220s sold in Europe were shipped from the US, or whether (as happened with other Heathkits) much of the kit was, but such items as transformers were locally sourced and were 50Hz transformers - saved a lot in shipping weight.
Japan has part of the country on 50Hz and part on 60Hz, while in the late 60's in France, it was 50Hz but the same 2 pin, no earth, plug and socket were used for both 110 AND 220 volt supplies!
