Author Topic: Wow! it's like a new radio : FT-817 speaker upgrade  (Read 36003 times)
AF6WL
« on: November 11, 2013, 09:38:51 PM »
I was comparing the audio between my KX3 and FT-817 :
The FT-817 lost by a large margin - lots of distortion even at low volumes.
A while ago trying to improve the audio quality of my K1, which also had a cheap paper cone speaker, I ordered two small Neodymium magnet, Mylar cone speakers AS05008MR-4-R and AS05008MR-R
http://www.mouser.com/ProductDetail/PUI-Audio/AS05008MR-4-R/?qs=%2fha2pyFaduiivYLHDCo0rrrKJR0%2fSirjAIaZYSe4rzduXq5v4jpm4A%3d%3d
and
http://www.mouser.com/ProductDetail/PUI-Audio/AS05008MR-R/?qs=%2fha2pyFaduiivYLHDCo0ri1LwBucfnzBcjHznaQENqZYExXT9o6rFA%3d%3d
I used the AS05008MR-R in the K1, with battery pack option, with great results.
Today I replaced the speaker in my FT-817 with the AS05008MR-4-R and all I can say is wow ! what a transformation .
It's very LOUD, crystal clear, distortion and resonance free  Smiley CW and SSB clarity are transformed.
Broadcast WBFM music is now outstanding - I've been listening to local radio playing classic hits for the last couple hours and enjoying it !
The heavy frame of the FT-817 makes for a great little speaker cabinet - now it has a modern speaker.
The upgrade is easy to do; all I need to do was cut a few rubber washers to space out the speaker from the top cover and one to cushion the speaker frame against the Yaesu's existing bracket.
W1JKA
« Reply #1 on: November 12, 2013, 06:10:56 AM »
Thanks for the info, I will order one of these speakers for my K-1 as I don't care for the flattish cw note from stock speaker so use head phones most the time. Another worth while addition to the K-1 is the use of a cheap outboard HyperMite audio filter especially used with the 2nd K1 filter setting.
KD0WZW
« Reply #2 on: November 12, 2013, 07:04:01 AM »
thanks for the info, I ordered a couple myself to do my 817, and a spare to play with as well.
KB4QAA
« Reply #3 on: November 13, 2013, 12:03:05 PM »
Thanks for the tip on speakers.  Definitely something to consider for improving clarity and listening ease.  bill
AF6WL
« Reply #4 on: November 21, 2013, 09:38:40 PM »
I also upgraded my new FT-817ND as it sounded just about as bad as the old FT-817.
It turned out they had exactly the same speaker despite 10 years of production.
I used 3x 1mm/0.04" thick rubber washers to space the speaker ( I had PSA backed rubber, but 3M spray adhesive would work just as well )
Take care to note where each screw came from - there are three different types.
New Speaker on left:
New Speaker on right: with 2mm of spacers
Now 3mm of spacers lower and the old foam ( just used to stop stuff sticking to the PSA ) plus one on the frame next to magnet and one piece incase the lower profile magnet slips
Ready to close the lid
M3KXZ
« Reply #5 on: November 29, 2013, 12:57:23 PM »
Brilliant upgrade this is, and it makes a great improvement to the audio clarity. Just done mine and it took all of 5 minutes.
I used a slightly different method in that I used just a 1.5mm spacer (I have some 0.75mm butyl pool membrane here and doubled that up) between speaker and case, and I removed the small rubber ring from the rear of the old speaker to use on the new one. To make it all tight, I just slightly bent the metal bracket.
For those in the UK who don't want to pay £12 for delivery from Mouser, Digikey or RS, then you can buy the correct speaker from Maplin Electronics. Their catalogue number is N96FU, description "Mylar Speaker 50mm". The specs are identical to the one shown here, and the speaker is identical in appearance. The massive difference is the cost in shipping - I just bought 2 of the speakers at £2.49 each, and paid £7.97 for the pair of them, including postage.
KK4YDR
« Reply #6 on: January 20, 2016, 09:40:18 PM »
I know this thread is old.
I just ordered this speaker for my radio. I hope to obtain the same results.
Thanks for posting this information and to the mods for leaving on the forums for people like me to find.
I just wished Yaesu 'The Radio" would upgrade and update the aged 817nd. I would buy one tomorrow if they did.
KB4MNG
« Reply #7 on: January 22, 2016, 03:55:34 AM »
I hope to have my k1 working very soon. Will this be a worthy upgrade for the k1?
K7EXJ
« Reply #8 on: January 22, 2016, 04:54:48 AM »
I tend to use an audio filter and a good pair of earphones but even so I'm tempted to try it. It's certain a cheap and easy mod.
One reason is that if I'm in a park and people wander by if I'm on the speaker then they know what I'm doing but can't understand what I'm sending (or the other stations). But I have a little CW decoder app on my Note 3 and with that they can read (more-or-less) the QSO. It saves questions but also gives onlookers (if there are any) a chance to be let into the club.
For $4 or so plus some shipping it's probably something I work around to.
Any more news on your K1?
73s de K7EXJ
Craig Smiley
KK4YDR
« Reply #9 on: January 26, 2016, 08:15:41 PM »
I just did this. For a small 4 dollar speaker it does tend to seem as if it sounds better than the factory speaker. It is smaller. Took me about an hour to install it because I had to look everywhere under my roof for my sheet of rubber gasket material. If I knew where it was it would have taken 10-15 mins tops. Took me a little longer because I have the bHi DSP module installed by W4RT. More wires to have to move about.
The speaker seems a little less noisy, hissy, and offers a little bit stronger voice although I think I lost a little tiny bit of lows, but that is nothing really because over all it seems more pleasureable to listen too. I use the internal speaker about 1% of the time the radio is on. I typically operate with headphones only.
KB4MNG
« Reply #10 on: January 27, 2016, 03:31:16 AM »
May stick with the stock speaker. How do you like the W4RT unit? Does it help?
KU3X
« Reply #11 on: January 27, 2016, 07:31:28 AM »
Do you know if this speaker will fit in the  KX3?  I'd love to replace that speaker.
Barry
KK4YDR
« Reply #12 on: January 31, 2016, 10:47:58 AM »
I LOOOOVE the Bhi Dps (W4RT). Awesome, just plain awesome. Sounds as good as an IF DSP, it might even be one.
I have done the speaker mod and I must say it does sound significantly improved. Remember it must be installed appropriately. With proper spacing and clearance for the sound to resonate properly. For a $4 modification it is $1000 worth of upgrade in audio to my ears.
M6YBM
« Reply #13 on: February 06, 2017, 04:34:49 AM »
I didn't fancy the trip to maplins & located an unused Bluetooth mini speaker with the same neodyn  speaker, free & sounds good  Grin
VE7OVY
« Reply #14 on: June 11, 2017, 08:45:15 AM »
Stumbled across this old post as I was searching for FT-817 articles.  Thanks to everyone who posted previously.
Ordered the Mouser speaker for my 1wk old 817ND and wow, remarkable difference in clarity and quality of voice and audio! The broadcast FM is the most improved, as it has the highest potential fidelity. Voices are crisper and cleaner. I pulled the old gaskets off the original speaker and reused them and bent the metal bracket a bit to hold the speaker tighter since its smaller.   Cheap upgrade and totally worth it!
