Pages: Prev 1 2 3 4 [5]   Go Down
Author Topic: wire size needed for paralleling batteries  (Read 52109 times)
W9FIB
« Reply #60 on: January 06, 2014, 03:59:22 AM »
Agreed. A fusible link is specifically designed for the purpose, and properly identified on the jacket that it is fusible link material. Which means it is not a random piece of wire to be burned as a safety device. A fusible link is a fuse. Wire is used to deliver power which is protected from overcurrent, melting, fire, etc. by the fuse.
73, Stan
Walk a mile in my shoes BEFORE you tell me how bad they are.
W6EM
« Reply #61 on: January 06, 2014, 06:12:24 AM »
You and VUL know what you're talking about.  What you've both said in the thread will help someone unknowing understand the risks of having a fire or serious injury from either not fusing or over sizing a fuse in DC circuits.  People for some reason think that an automotive DC system doesn't have the same risks as a residential AC system does.  Sure, no shock hazard, (except for plug wires) but the energy in a typical battery is capable of some pretty serious damage.
I run a 6AWG feeder from the battery via a 60A cartridge fuse encased in wire loom at the point of connection, then a 30A fuse on the small custom fuse block under the back seat.  I then have 15A branch positions on the block.  All covered up.  My FT-8900 sits right next to it under the back seat.  Minimal voltage drop on transmit and no worries about where a fault is, if one happens.
« Reply #62 on: January 06, 2014, 07:40:38 AM »
Just a thought--instead of continuing to feed the trolls, I use the 'ignore' button.  'JX has been on ignore (for me) for quite a while now.  73!
K5TED
« Reply #63 on: January 08, 2014, 08:36:38 PM »
Here's how I do it. Separate pair for each battery, individually fused.
http://k5ted.net/slide_show.html?show=2012_Field_Day&picture=picture7.jpg
http://k5ted.net/slide_show.html?show=2012_CQ_WW_VHF&picture=picture6.jpg
W9FIB
« Reply #64 on: January 09, 2014, 03:08:44 AM »
Very nice! Well protected too. Thanks for sharing.
73, Stan
Pages: Prev 1 2 3 4 [5]   Go Up
