Author Topic: start logging first or last  (Read 5999 times)
K2JF
« on: December 13, 2013, 12:57:42 PM »
Does it really matter whether your logging program starts first and then the rig is fired up - or whether the rig is fired up and then the logging program is opened?
AA6YQ
« Reply #1 on: December 13, 2013, 03:04:18 PM »
If your transceiver is a recent model (IC-7200, UC-7410, IC-7600, IC-9100, TS-590, TS-990) that includes a USB interface that emulates a virtual serial port, and you're using this USB interface to connect your computer to your transceiver, that virtual serial port will not exist before you power up the transceiver. In this case, it will be easier to power up the transceiver before you start an application that communicates with your transceiver. If you your transceiver is connected to a serial port or USB-to-serial-port-adapter in your computer, then it shouldn't matter whether the transceiver is powered up before or after such an application.
            Dave, AA6YQ
N8YQX
« Reply #2 on: December 19, 2013, 06:23:27 AM »
            Dave, AA6YQ
Yep.  I can personally verify that HRD gets screwey if I don't turn on my IC-7410 first.  DM780 also seems to revert back to the internal sound card if the rig is not turned on first.
N8YQX
