Author Topic: Is the IC-706 grid or cathode keyed  (Read 5217 times)
HS0ZFQ
« on: December 16, 2013, 08:44:59 PM »
Greetings:
       I would like to buy the Idiompress Logikey k-5 keyer and it says to not use it with a cathode keyed rig without an isolating transformer.Can  I use the IC-706  as is with the K-5?
Thanks in advance
RICHARD D Vincent
HS0ZFQ
KQ6Q
« Reply #1 on: December 16, 2013, 09:55:35 PM »
the 706 is solid state. Grid or cathode keying refers to tube rigs. any modern keyer will work with a 706 - but it has a built in keyer, why don't you just use paddles and the internal keyer ? Read the manual on it!
HS0ZFQ
« Reply #2 on: December 16, 2013, 11:56:22 PM »
I want the K-5 keyer because it has a lot of memories you can use. I had a stroke 5 months ago and could really use  for instance calling cq in a loop etc.I have read that manual many times in the last ten years. Thanks for the help.
Richard
KA9CCH
« Reply #3 on: December 18, 2013, 08:16:38 PM »
In tube rigs cathode keying can have high voltage at the key.  Do a search on cathode keying.
 Anyway, the 706 is not a tube rig so you'll probably be fine.  If you have any doubt, drop an email to the vendor of the keyer.
GL
KA9CCH
KB4QAA
« Reply #4 on: December 18, 2013, 08:33:14 PM »
Just plug into the CW Key jack on the back of the 706.  1/4 inch 3 conductor.
KT4WO
« Reply #5 on: December 27, 2013, 04:31:15 PM »
The 706 is Bipolar keyed...you must have Lithium to use it.
Smiley
« Last Edit: December 27, 2013, 04:35:05 PM by KT4WO » Logged
