Author Topic: Mobile 2/70 on Jeep Wrangler  (Read 17977 times)
W5FQZ
« on: December 26, 2013, 12:29:24 PM »
I have a 98 Jeep Wrangler and have a Teraflex mount behind the tail light on the passenger side.  Over the past two months I have had both antennas stolen.  This is really a two part question.  First, I owned a MFJ-1402 and a Diamond NR770HBNMO and these were the two that were taken.  I liked them both as neither gave me any trouble, but was wondering what your opinion is for a replacement, and second, does anyone know of a way to secure these antennas a little better or at least make removing them more troublesome that what it would be worth?
Levi
W5FQZ
KB4QAA
« Reply #1 on: December 27, 2013, 08:47:57 PM »
I remove my antennas and put them in the trunk when I'm parking anywhere they might be stolen....
W5FQZ
« Reply #2 on: December 28, 2013, 12:51:41 PM »
That is probably what I need to do.  I just don't understand.  I don't live in a place where there are a ton of hams, and they really can't be used for anything else, but who knows?  Any advice on a good quality, reasonably priced antenna?
AA4HA
« Reply #3 on: December 28, 2013, 03:55:15 PM »
People will steal stuff just because they can. Usually they toss it in the bushes somewhere else. It is just their way of making someone else as miserable as they normally are.
Ms. Tisha Hayes, AA4HA
Lookout Mountain, Alabama
N5OHQ
« Reply #4 on: December 30, 2013, 12:59:05 PM »
I have a 2012 wrangler with the black soft top. Make a mount from the tire carrier out past the edge of the tire. pick out your favorite 1/2 wave antenna that is black and no one will see it. third jeep no problems
HURRICAINE
« Reply #5 on: January 01, 2014, 07:35:34 PM »
All vertical antennas needs some sort of ground plane directly underneath the antenna.
The ground plane for two meters is about 3 feet square.
Hence a pizza pie pan is not of sufficient size to work as the ground plane, so a spare tire mount is definitely too small to work efficiently.
If you have a soft top the only metal surface left is the hood - eh.
Well the problem with the hood is that it picks up the noise from the engine, computers, alternator etc.
A Jeep is a tough row to hoe when it comes to transmitting antenna's.
None of this is taught anymore so it is a wonder that anyone would even think of putting a 2 meter antenna on a Jeep like that.
There is nothing to keep you from painting your antenna with florescent paint or scribing your name someplace on the antenna is there.
Once it is stolen there isn't much of any way to prove who stole it.
It would be like trying to identify a fishing pole.
What about welding a plate to a roll bar and placing the mag mount atop the plate with the top between the plate and the mag mount.  It would not establish a good ground between the two, but it might keep it from being stolen.
Most people probably confuses your antenna with a CB radio antenna, and they probably don't find out that it won't work on 11 meters until after they steal it.
Then again, most CB radio people today do not own a SWR meter, so they wouldn't know the difference.
KK4LGR
« Reply #6 on: January 06, 2014, 02:17:07 AM »
If a ground plane is a problem, why not stick an Ed Fong-type J-pole on the car?
"Well I'm sure glad we've got these ham radios to talk on."
--Unidentified station heard on 2 meters
M6GOM
« Reply #7 on: January 06, 2014, 06:06:17 AM »
I don't bother with 70cm any more and just use commercial VHF mobile antennas like this one. They're not big and shiny with coils on making them look expensive. You need to cut them to length.
http://www.ebay.co.uk/itm/COMPLETE-VHF-ANTENNA-162-174-MHZ-CABLE-BODY-MOUNT-WHIP-by-PANORAMA-PL259-/270890182641?pt=UK_ConsumerElectronics_SpecialistRadioEquipment_SM&hash=item3f125027f1
Replacement antennas are £10 a go. Doing a side by side comparison with my Diamond NR770 with the 5/8 version of these antennas there is absolutely no difference.
KD8NGE
« Reply #8 on: January 19, 2014, 03:05:23 PM »
I can offer no help on theft deterrence (save maybe applying grease to the antenna so it's difficult and messy to grip)
A comment was made about the spare tire mount being an insufficient ground plane.
I chose the spare tire mount by Arizona Rocky Roads,but took two additional steps, thanks to comments on the Jeep boards about the difficulty of a good ground with a tailgate mount:
First, all metal to metal surfaces, including bolt threads, I burnished down to bright metal and applied a healthy coat of Anti-Seez compound:  Never-Seez and Anti-Seez are both powdered aluminum or powdered bronze in petroleum grease, intended to prevent screw threads from rusting and seizing up.  The powdered metal in suspension helps guarantee conductivity between the bare metal surfaces.
Second, I took four feet of plated wire a buddy gave me from his wire welder; I bent an eye in its center just the size of the threaded NMO antenna stub; a few minutes' work with pliers and I had three wire arms:  with the antenna tightened down on the center eye, a tape measure and careful trimming, I now have two nineteen inch counterpoise arms, one to starboard and one to port, and a third ... more of a finger, about six inches long, pointing straight back.
My theory:
If a tiger tail enhances an HT antenna by providing a counterpoise, then it just might help my Diamond "no-ground" antenna; nineteen inch arms for 2 meters, the 6 inch arm for 70 cm ...
Disclaimer:
I am neither an antenna guru, nor am I the brightest bulb in the chandelier.
I am just a poor dumb hillbilly with an idea.
Your mileage may vary.
KK4IRX
« Reply #9 on: February 21, 2014, 12:36:34 PM »
Would love to see a pic of this if possible. Great idea!
W7HBP
« Reply #10 on: February 23, 2014, 11:07:29 AM »
Levi
W5FQZ
I'd get an NMO type mounted antenna from Larsen and get a weather cap also, unscrew it, install weather cap, problem solved. Just a pain to have to remove it all the time. I'm certain someone thinks they are getting a cool CB antenna and cant figure out why their SWR is so high.
Reviews on this webpage: http://www.eham.net/reviews/detail/434
And: http://www.hamradio.com/detail.cfm?pid=H0-000565
I like to get them in black, they dont stand out as much as the chrome units.
ARRL Life Member|QRZ Life Member
