Author Topic: Dodge Journey rack antenna question  (Read 4458 times)
VA7NAD
« on: December 27, 2013, 08:22:34 AM »
Greetings!
I am mounting a quad band antenna on the roof rack of my Dodge Journey, as well as a mobile somewhere on the dash. Can anyone suggest a "safe" route to run the antenna wire inside from up top? I want avoid drilling holes, I renew my vehicles frequently due to milage on the job. I'm also open to suggestions as to how to run the power wires from the battery to the inside, and where to mount the remote faceplate/control on the dash. I have a Wouxun KG-UV950P quad band, and a Comet antenna to match.
Thanks
KQ6Q
« Reply #1 on: January 01, 2014, 09:17:30 PM »
Save yourself some grief, use a hood lip mount (actually bolts to the innner lip of the fender) for 2m/440, makes running the wires simpler.
But you want a short antenna in your field of view - a longer one will whip around at highway speeds and be very distracting. You can probably run the power wires and the coax out through the door opening, let the door gaskets compress around them.
for 6m/10m, you'll want roof antennas, but if mag mounts are out of the question, mount to the roof rack. to keep life simple, route the coax through the least used door opening. (driver's side rear door usually). Plan for a fold down antenna mount if you will EVER need to enter a parking garage with less than 7' clearance.
VA7NAD
« Reply #2 on: January 01, 2014, 09:35:43 PM »
 I am planning to mount a quad band antenna that has a fold-down feature, I just don't trust myself to remember to stop to do it before entering a garage. Maybe a fender mount would be a logical alternative. Thanks for the post!
VO1GXG
« Reply #3 on: February 16, 2014, 07:22:17 PM »
I would suggest a lip mount on the top of the gate or a lip mount on the hood. I am not a fan of mag mounts myself.
