Author Topic: Contesting with remote radio  (Read 14704 times)
NO9E
« on: January 16, 2014, 06:00:50 AM »
Lately, in contests, some fraction of stations seem to respond with half a second delay, or longer. Could they be remote stations?
Extra questions:
What is the minimum delay over internet with good connections and fast computers?
What is the maximum real delay when the operations seem smooth?
Ignacy, NO9E
K0IZ
« Reply #1 on: January 17, 2014, 05:59:29 PM »
Half a second is a pretty long delay in a contest.  I operate my station in Colorado remotely.  K3 plus amp, using serial server and Skype.  My latency is about 75ms, and not noticeable.  I operated last year's Colorado QSO Party remotely, 1070 contacts on SSB 20 meters in 15 hours.   I use VOX.  An efficient remote set up should not be particularly noticeable to other station.
N9RO
« Reply #2 on: January 18, 2014, 04:13:44 PM »
NY to San Francisco 21ms (via fiber) so you can begin from there if going cross country.  Most folks will reliably report a perceptible lag when a delay of 100-200ms is introduced into a system.
Often times it is the last-mile where the delay is introduced. Your ISP needs to route the data thru the neighborhood, aggregate the data, and forward for routing, in some cases this can take tens of milliseconds just to get to your ISP’s main routers (this last-mile delay figure was determined by the FCC in the “Measuring Broadband America” report).
Tim, N9RO
Real techies don't use knobs.
N4OGW
« Reply #3 on: February 25, 2014, 10:48:04 AM »
Extra questions:
Ignacy, NO9E
That can also be multi-op stations who are interleaving running and S&P on the same band. They call you, you send the report, then there is a long pause before they respond. I got several of those in the CQ160 CW contest. Sometimes it gets annoying: one big east-coast station called me three times over about 15 minutes before they got the timing right in order to reply!
Tor
N4OGW
