Author Topic: Implementing phase shift for Image rejection?  (Read 7982 times)
VA2FSQ
« on: January 24, 2014, 05:41:27 PM »
HI,
I know there is a number of algorithms for adjusting the phase relationship between the i and q signals.  I was wondering if it is possible to do so by introducing a sampling delay between the two channels when the audio is digitized?
What other simple techniques could be done?
Thanks
VA2FSQ
PJ2BVU
« Reply #1 on: January 25, 2014, 06:55:32 AM »
Visit http://dxatlas.com/Dev/
Scroll down to the DSP section, the last item is I/Q Balance Correction which the Delphi (Pascal) source code for automatic estimation and correction of the I/Q balance error in the QSD-based SDR receivers. Part of the Rocky project.
Note: I did not look at it, I just noticed it while looking for something else.
Jean-Claude PJ2BVU
W6RMK
« Reply #2 on: January 25, 2014, 08:29:29 AM »
Yes you can adjust the timing of the sampling, but that's kind of a pain in most systems, because you tend to drive all the sampling off the same clock (either sampling I/Q simultaneously, or alternately).
You can also do it by implementing a delay (using any of a variety of interpolation schemes) in the digitized path.
One thing you want to decide is if you need a phase shift or a time delay across the audio band.
If you're compensating for the imperfect 90 degree phase shift in the RF path, over a small band (e.g. a few tens of kHz), the RF phase error is typically fairly constant, so you want a phase shift in the I/Q, which you can adjust as the RF frequency changes (it's hard to keep 90 degree quadrature over a decade bandwidth)
But if you're adjusting for imperfect 90 degrees in the I/Q path (e.g. the low pass filters before the ADC or after the DAC) you probably want something more like an equalizer that adjusts for timing skew (phase shift a linear function of frequency) or filter non-ideal behavior (phaseshift changing rapidly near poles of the filter).  A FIR equalizer is a pretty general solution, depending on the performance you need.
Note that getting 40dB image rejection requires fairly good performance. The phase error has to be less than arcsin(0.01) or 1/2 degree.  The gain balance has to be within 1% for the same reason.
VA2FSQ
« Reply #3 on: January 25, 2014, 04:29:40 PM »
Hi
Thanks for the answers.
It's not an issue for the amplitude  imbalance, I've got that down as far as I can.  But the phase imbalance is different.
In the software I am using there is the possibility to delay the I or Q by samples, (1 or more) or by milliseconds in the digital domain. I probably need to delay by microseconds, and I'm not sure it will work at that level of granularity although a 1 sample delay at 192kHz is about 5 microseconds.
I also heard that for small imbalances in phase you an inject a very small amount of the Q signal into the I signal.  Not sure how to implement this though.
The interesting thing, is with my software I can get at least 40db down with the Elecraft KX3 using only amplitude balancing.  Using an LP-Pan the best I can do is about 20b.  However, if I do shift the I/Q signals by one sample, then there is another drop of about 10db going from 0 to one.  This implies that perhaps the channels are skewed by 1 sample (sampling at 192kHz), irrespective of an actual phase shift.
Lots of fun and lots of learning!  One wouldn't know an equation to vary the phase for the Q channels by any chance?
Thanks, Tom
VA2FSQ
W6RMK
« Reply #4 on: January 26, 2014, 10:28:49 AM »
It's not unusual for there to be a timing skew between the channels.  Have you got an oscilloscope or can borrow one?  Play a sinewave through both channels at the same time and it will be instantly obvious.
As far as adding some of I or Q to the other to do a phase shift... that works for a sine wave, where you're sending cos(2*pi*f*t) to I and sin(2*pi*f*t) to Q and you want to shift the phase a bit (e.g. cos(a+b) = cos(a)cos(b)-sin(a)sin(b)... if a is 2*pi*f*t and b is the desired phase shift, you can see that you can get it by adding a bit of I and a bit of Q (e.g. cos(b) of I and sin(b) of Q)
However, it doesn't necessarily work as a general thing for a broadband signal: most systems don't have constant phase error over frequency: they have a time delay (which requires a variable amount of that cos(b),sin(b) term, because phase varies with frequency) or some other non-matched behavior (most often at high or low frequencies, because of component tolerances)
There are fairly simple FIR interpolators that can do a "fractional sample delay".  However, most of them  have a range of delays around half the filter length.  Say you have a filter that is 5 taps long, and you can adjust the taps to make the delay anything between 2 and 3 samples.  So you'll need the same thing in both sides, to match the delays.
VA2FSQ
« Reply #5 on: January 27, 2014, 07:29:27 PM »
Hi,
Thanks for the answer, but it will take a while to digest.  It's been a while since my physics and math courses...none the less, that never stopped me before.
So as a starting point, would you consider this reference as appropriate?
http://dsp.stackexchange.com/questions/4709/phase-shifting-of-50hz-signal/4715#4715
So apart from the linear interpolation, I would have a pair of fir lowpass interpolators and vary one so as to have fractional time delays?
Thanks, Tom
VA2FSQ
W6RMK
« Reply #6 on: February 02, 2014, 07:41:32 AM »
Yes. that's one way to do it.
If you look up "interpolators" that might help too..
Do you have an overall latency requirement?  a scheme with FFTs can also work: you take an FFT of the input signal, multiply it by the frequency response (amplitude and phase) you want, then inverse FFT. This might be faster, computationally, but is tricky.
