Author Topic: Sky Command Audio Issues  (Read 10494 times)
N7KFD
« on: February 08, 2014, 02:56:46 PM »
I'm looking for someone who has experience with Kenwood's Sky Command setup. I'm running a TS-480SAT with a TH-D7 through a TM-D710. I can key the 480 but I can't hear the 480's audio in the D7 (after pressing 2) and audio is not getting from the D7 to the 480. I built the cables myself and have triple checked them to make sure they are correct, I just can't seem to find the problem.
Thanks in advance,
Jim
N7KFD
N7KFD
« Reply #1 on: February 10, 2014, 09:22:42 PM »
If anyone has this problem in the future here is a link to a web site http://www.tigertronics.com/sl_wirebm.htm that has a better picture of the mic connector which makes it easier to figure out what pair you need in the ethernet cable. If you're using a standard cable its Blue and Green/White.
