Author Topic: Which 2-Meter FM Mobile Rig To Buy?  (Read 12906 times)
N3BQA
« on: February 12, 2014, 08:42:24 PM »
I'm in the market for a new 2-meter FM mobile rig. I'm looking for simplicity in programing & operation. Only interested in 2 meters, no dual band rig. Simplicity is the priority! What's available?
M6GOM
« Reply #1 on: February 13, 2014, 03:51:43 AM »
None of them. They're all a pain in the ass to programme.
I suppose the Kenwood TM-281A is about the best.
K7RBW
« Reply #2 on: February 13, 2014, 06:08:20 AM »
I'd also put in a vote for the Kenwood. It's a very solid radio.
« Reply #3 on: February 13, 2014, 06:14:31 AM »
I know Yaesu radios offer a "memory only" mode, reducing operator input to turning the knob to the desired memory and that's it.  But you'd have to come up to speed setting up the memories and radio functions initially, so that may not meet your simplicity requirement.  Unfortunately, the only "simple" synthesized radios I've seen are from three decades ago, so you may have to get with the times if you want something contemporary.
Alternatively, something like a motorola maxtrac is as simple as it gets.  On-off/volume and channel up/down are the only controls you get.  You need an interface and software to set those up, so even a "simple" radio requires some degree of complexity to get going.
KE5TJT
« Reply #4 on: February 13, 2014, 03:12:22 PM »
I highly recommend one of the Yaesus. They work great. They are a vertex standard company. I have an old Vertex Standard HT for aircraft use and it works like new with the original battery, except it's about 10 years old!!!!! The thing is built like a brick ***thouse.
KA3NXN
« Reply #5 on: February 13, 2014, 04:14:49 PM »
All the name brands are fine. I personally own several Alinco single band rigs that are very, very easy to program and are affordable.  My 2m version is the DR135MKIII.
Jaime-KA3NXN
« Last Edit: February 13, 2014, 04:17:58 PM by KA3NXN » Logged
N6AJR
« Reply #6 on: February 17, 2014, 01:29:04 PM »
ft 1500
ONAIR
« Reply #7 on: February 17, 2014, 02:59:59 PM »
Yaesu FT-2900.  75 Watts, solid as a rock, a cinch to program!
N1DYX
« Reply #8 on: February 19, 2014, 09:09:26 AM »
I have a 2900 and I think it's a poorly made rig as far as the handset is concerned.  Also the speaker points down towards the floor, OK if you're laying on the floor but otherwise hard to hear in a vehicle that has a slightly higher noise level.  The Kenwoods I've had in the past have the speaker on top where it should be.
Agree on the ease of programming and all other functions.  Pretty economical 75watt radio.  No complaints on transmit or receive.
« Reply #9 on: February 19, 2014, 09:35:48 AM »
I have owned one for a year and a half and it is a solid rig with strong/loud audio on receive.
WY1C
« Reply #10 on: February 19, 2014, 11:49:28 AM »
FT-2800, Best 2m ever, easy to program.
W7HBP
« Reply #11 on: February 23, 2014, 11:10:53 AM »
I liked the Alinco DR135 for ease of programming and they have 100 memory channels too. I found Yaesu and Icoms are complicated compared to Alinco. I have no expereicne with Kenwood units.
ARRL Life Member|QRZ Life Member
VE5EIS
« Reply #12 on: February 23, 2014, 06:22:35 PM »
I run the Icom IC-2300H.  Cheap, 65 watts, reasonably easy to program, 4 power settings (5/10/25/65) and nice and compact, too.
K6CPO
« Reply #13 on: February 24, 2014, 03:44:09 PM »
Jaime-KA3NXN
I found the Alinco 6 meter FM mobile more difficult to program than the Yaesu FT-1900 2 meter mobile or the Yaesu FT-7900 dual band mobile.  Programming any radio is made much easier with software, but none exists for my particular Alinco...
W7ND
« Reply #14 on: February 26, 2014, 05:06:43 PM »
I had a Kenwood TM281A.  Great radio, very easy to use and operate.  My only gripe with it was it only has two power level settings, a high setting of 65 watts, and a low setting of 25 watts.  I wished it had a setting lower than the 25 w as I often just used mine for repeater contacts around town that were easy to hit on low power.  Also, if you're ragchewing, especially on high power, the heatsink could get quite hot.  I had mine mounted in such a way my leg would occasionally come into contact with it, and  I just about burned myself a couple of times wearing shorts.  I suspect pretty much all the radio mentioned in this catagory (Yaesu 1900/2900, Icom V8000, Alinco 135) are in the same boat as they have big aluminum heatsinks for cooling instead of fans.  Speaking of the Alinco, if you later on decide you want to do packet or APRS with it I believe it has a TNC add on board for the radio so you won't need an external TNC.
