Author Topic: Which 2-Meter FM Mobile Rig To Buy?  (Read 12682 times)
K7EDL
« Reply #15 on: February 27, 2014, 01:58:57 PM »
Another vote for the Kenwood, easy to program and good clear sound in my noisy truck with my faiding hearing
KD0PBO
« Reply #16 on: February 27, 2014, 09:33:31 PM »
BIG +1 for the Kenwood 281A.
I have had its older brother, the 271A for around 3 years in my truck. Through 100+ degree heat in the summer and below 0 degree cold in the winter (specifically this winter) and it has fired up every morning. Built like a tank with a front firing speaker to boot. Run it on low power of 25w instead of 65w and it'll last forever. Easy to program too once you learn the sequence of buttons.
KC8Y
« Reply #17 on: March 01, 2014, 06:57:52 AM »
RE W7NBD statement ...about the ICOM IC-V8000
I've had the IC-V8000 2-m xcvr ever since it came out.  True-it's a bear to program, BUT I bought RT System programming software for it,  problem solved.
I, also like the front facing speaker (only use the unit for a base station), and
the multi-power outputs, only run about 20-watts.
Guess everyone can make their own decision for a rig.
Ken KC8Y.
VE4CDR
« Reply #18 on: March 02, 2014, 03:45:23 PM »
Another vote for the Icom IC-V8000. Choice of power levels, front facing speaker with good volume and built like a locomotive. The programming is incredibly non intuitive. After owning it for 2 years, I still have to use the manual to program it if I am unable to use the RT software. A great choice if all you need is 2 meters.
