Author Topic: MORSE CODE BEGINNER II FOR CW LEARNING  (Read 11838 times)
BA8IK
« on: February 19, 2014, 07:37:53 PM »
l  MORSE CODE BEGINNER II supports ELE-key and straight key learning, dual-Paddles key can also be used as BUG key.
l  Wide range of power support. Support earphone monitoring and volume  adjusting.
l  Turn on or off the sound when connecting equipment that can adapt all kinds of radio.
l  When the two Paddles are pressed at the same timeļ¼Œ dot-dash interleaved transmission. The last dot or dash memorizing function.
l  The training of dictation and sending code can be done in practice and test modes ,sequential or random mode can be selected.
l  Connecting with HF and UV radio perfectly, convenient to practice and self test.
l  MORSE CODE BEGINNER II can become a CW decoder by increasing external audio PLL circuits.
you can get more information from:http://gicwork.blogspot.com/
email adress:xuyancq2010@gamil.com
VK6IS
« Reply #1 on: February 20, 2014, 03:18:00 AM »
JEEZ - YOU DON"T HAVE YELL - y'know
and the price is ?  ~$100 ish
http://www.ebay.com/itm/Autokey-Morse-Code-Beginner-II-CW-Trainer-Ham-Radio-Morse-Code-/350900124293
- looks nice tho
- had a less fancy one many years ago, when 1st learning CW.
which finally died, when it's capacitors eventually gave out.
K5UNX
« Reply #2 on: February 20, 2014, 08:34:54 AM »
So the dumb question . . what does a person do with it?  Learn to send?
PA0WV
« Reply #3 on: February 20, 2014, 09:48:59 AM »
Sure,
When your timimg of dots, dashes and spaces is 50 % off the required value, you got perfect copy.
So be lucky you can't get a drivers license when you drive a car with that tolerance through traffic.
