Author Topic: Tarheel Antenna Little Tarheel II Mount  (Read 2785 times)
KA4NMA
« on: February 20, 2014, 12:11:48 AM »
Any suggestions for mounting this antenna on a Ford Focus with a sunroof?  I like the Breedlove mounts, but they are too expensive.  I have no problem with drilling holes.
Randy ka4nma
M6GOM
« Reply #1 on: February 21, 2014, 04:09:43 AM »
After trying various 3/8 body mounts over the last few years and finding I had to replace them every 6 months because they use press fittings internally that do not stand up to the side load put on them by a screwdriver antenna your best options are:
1) Breedlove mounts.
2) The 3/8 mount assembly used on the Diamond K400 antenna but you'd need to strengthen the roof area around it by putting a thick metal sheet under it.
I really would spend the money on the Breedlove. You'll fit it once and that's it. With the others, a few months down the line you'll be driving down the road listening to the audio going in and out and wondering if you've a loose connection. You don't, its yet another crappy mount failing.
