Author Topic: First Alert CO614 Carbon Monoxide alarm triggered by 80 meter RF  (Read 12674 times)
W3VVV
« on: February 25, 2014, 02:17:17 PM »
I have a First Alert CO614 carbon monoxide alarm that has been getting triggered sporadically when I transmit on 80 meters.   At first this was just a nuisance, but now the alarm has gone into permanent "error" status according to the display.   The manual says that "error" status means "malfunction - replace alarm".   I called First Alert and they took a "report", but I don't know if they'll actually do anything to make the newer CO detectors more RF-resistant.  (I bought the alarm at Costco, so they'll give me a refund with no problem.)
Anyone else seen this behaviour with CO alarms, particularly the First Alert CO614?   Anyone else have a CO alarm that appears to be RF-immune?
Louis
W3LMW
KD0PBO
« Reply #1 on: February 25, 2014, 05:27:02 PM »
We have a similar First Alert model that gets tripped into "error" mode when I occasionally key up on 2 meters with only 5 watts. Starts the error "chirp" and continues until I take the battery out. Running 1w to hit repeaters seems to help and using UHF/HF doesn't seem to effect it.
You aren't alone my friend!
EDIT: I should add that 80m may trip mine as well but I do not operate enough on that band to say.
« Last Edit: February 25, 2014, 05:31:45 PM by KD0PBO » Logged
K3LRH
« Reply #2 on: February 26, 2014, 05:14:45 AM »
.....yep, same thing here.  Unplugged, removed battery and threw the whole thing in the trash.  Bye bye.
W2JUV
« Reply #3 on: March 07, 2014, 04:44:32 AM »
Original post didn't state if the CO detector operates on 120vac or battery.  I had a similar situation with a detector that plugged into 120vac and I set it off when operating 160m.  Replaced with a battery powered unit....problem solved.
W3VVV
« Reply #4 on: April 12, 2014, 06:44:38 PM »
CO614 operates on 120 VAC and has battery backup.   Replaced unit with a battery powered unit and problem is solved.
